Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine Diagnostics
- Mercedes-Benz C-Class and AMG: Why Does My Car Smell Like Fuel?
Guide to diagnose trouble and recommended solutions
Gas Smell after fill-up
C240 - 6 speed
I filled the car up the third time since I purchased it, and it has done this every single time. I fill up until the pump clicks, then close the gas cap, and
go home put the car in the garage.
Then the whole garage smells of gas.
I am thinking maybe the gas cap is leaking and causing gas fumes to escape, or I have a gas leak. The fuel mileage is in 19-20 mpg which sounds bad for a 240 but not that bad. So I am leaning towards a bad gas cap. I have never had a bad gas cap in any of my other cars before and I did not want to have one in this car.
So far owned the car for 1.5 months and have been at the dealer three times. Sure love that Starmark certified experience.
C240 - 6 speed
Re: Gas Smell after fill-up
Boy, at what you guys pay for gas up there you want to account for every drop. Has premium hit $2.50 yet? The cheapest of the cheap stations by me are at a little over $2.
C240 - 6 speed
I dropped the car off today and basically told them I don't want it back until they fix it.
I have three other cars, so I am not in a hurry to get it back.
2002 C240 6-spd (ret)
That's interesting -- I'm wondering why you didn't get the check engine light coming on. They always say if the cap is loose, the OBD II (whatever) will detect it. Is a leak further down similar in that a seal to the atmosphere is broken?
C240 - 6 speed
C240 - 6 speed
Dealer just called, gas tank is cracked where it attaches to the fuel filler neck, it is not the neck itself. They need to get a new tank from either germany or east coast. Estimated down time 3-4 days.
I don't know what's involved in getting a new tank installed, but any recommendations on what else I should have them look at while they are in there.
2010 C300 4matic
I had a new tank put in my coupe for a different problem. I'm not sure if it's in the same place in the sedan, but they had to unbolt the right side of the rear subframe. If they have to do that, make sure they do an alignment.
If the tank is really the problem, then there shouldn't be anything else to worry about while they're in there.
Guest
Posts: n/a
1 Post
2002 C230 Coupe(M111)
2010 C300 4matic
Re: Re: Gas Smell after fill-up
Originally posted by Outland
Certainly something like that should have been noticed by the previous owner...at least an owner with a nose
C240 - 6 speed
Re: Re: Re: Gas Smell after fill-up
Originally posted by Matt230K
Well, it probably just happened, but if not, then that may be one of the reasons that they got rid of it.
I like the car, never had a problem like this with either my Porsches or BMWs.
Oh well, as long as it is fixed, I am happy. In the meantime I will ask them about the alignment.
2010 C300 4matic
Re: Re: Re: Re: Gas Smell after fill-up
It did not **JUST** happen, we noticed the terrible gas smell after we signed the paperwork and drove the car home from the dealer with a full tank of gas.
C240 - 6 speed
Re: Re: Re: Re: Re: Gas Smell after fill-up
Sorry, I had to reread above where you said it happened with every fill-up since you got it.
This is if you could not smell the gas in the garage, my whole house was smelling like gas after a while.
2002 C230 K
Frankly I'm often amazed at people's powers of un-observation.
My guess (since this is the Bay Area) is that the previous owners may not have had a garage and therefore never noticed any smell.
- BT
- BT
C240 - 6 speed
- BT
- BT
to park in the garage.
C240 - 6 speed
Dealer called, new gas tank has arrived, it is going to take them 2 more days to put it in, apparently driveshaft and differential needs to come out as well as the sway bars but not the trailing arms etc.
Well I sure hope they don't break anything else in the process.
