Help! Left tire rubbing against wheel well
#51
C320 tires 225/40 zr18 92y
Hi phister can you send me a picture of your fuse box in the trunk I'm missing fuses in
5
6
7
11 12 13 14 16
Can you let me know if you have any in these slots I the trunk thxs
5
6
7
11 12 13 14 16
#52
06 C230 SS 6spd
You should have diagram sheet on the inside fuse box. Just open the driver door and pop off the plastic piece on the side of the dash. There should be a folded up diagram sheet for all the fuses
#56
Back to the wheels they are all egg shaped so either straighten I'm sure not cheap or replace any ideas of the offset I would need and if the offset changes will my new tires still fit thanks again phister I'm looking on pepboys to ensure they aren't bent
