- Mercedes-Benz C-Class AMG: How to Replace Motor Mounts
Step by step instructions for do-it-yourself repairs
Browse all: Engine Guides
c320 Engine Mounts replacing?
I pulled up the procedure on the wis and it specifies to remove the entire exhaust system.
Seems a bit more trouble that I am ready to get myself in to.
I searched around and found a few diy posts that specified using a piece of wood on a jack and raising up the engine enough to get the mounts in and out, but they weren't specifically working on a w203 v6.
Has anyone else replaced their mounts that can give me some advice?
Thanks in advance.
Yes, you do have to remove the exhaust. As far as lifting the engine that would be helpful once you already have the exhaust off...easy if u have a lift ..lol ........But for a rattle? mounts? it should make a noise in neutral just reving the engine....
