Pulley FEA
Rating: Thread Rating: 6 votes, 5.00 average.
Old Feb 24, 2003 | 04:17 PM
  #51
20FHK02's Avatar
2002 C230 Coupe
Buellwinkle:
The weight of the all-alloy ASP pulley before the steel hub was around 6 lbs right? Just want to make sure the density is right because rotation depends on mass. Thanks!
C230 Sport Coup:
It was a theoretical comparison simulation before, but now it's going more toward reality.
Old Feb 24, 2003 | 09:32 PM
  #52
20FHK02's Avatar
2002 C230 Coupe
An T6061 alloy pulley with 0.07" thick steel sleeve seems fine under static loads at steady 4000 rpm. I may do a frequency sweep for vibration if I have time tomorrow - just for my own curiosity though. But modal analysis is always a nightmare.
Old Feb 24, 2003 | 10:23 PM
  #53
Buellwinkle's Avatar
The ASP alloy pulley weighs 5 lbs 1 oz. The steel hub adds 8 oz.
Old Feb 25, 2003 | 07:39 PM
  #54
20FHK02's Avatar
2002 C230 Coupe
Today I tried to put gap elements to simulate actual shaft contact (i.e., only support compressive contact onto the shaft surface) but they confused the contact surfaces on the steel sleeves so it didn't work... I've decided to let this slip through.
There is no point on keep doing the steel sleeve version when the one I'll be putting on is the steel hub version. So when I have time I'll do the hub version instead.
Peace,
FHK
Old Feb 25, 2003 | 07:41 PM
  #55
20FHK02's Avatar
2002 C230 Coupe
This should be within the margin as I did not take out the material on the belt grooves.
Old Feb 25, 2003 | 09:40 PM
  #56
Brandon @ Kleemann's Avatar
Former Vendor of MBWorld
It's a high number like 180-200 lbs.
Jeezus- not even close. Try 100 lbs.
No one will offend/insult or otherwise incur a legal wrath from me posting FEA results for our pulley. Ive seen them before from the manufacturer of the pulley- so post away!
If you really want to do this right (which you cant possibly be doing if you dont have the DIM's for the pulley) shouldnt you confer about the actual pulley specs rather than guessing?
Also, wouldnt it be mildly useful to have the power required to turn all the individual accessories and their relative position to the crank pulley? (at least in so far as the two belt departures from the crank)
Old Feb 25, 2003 | 09:49 PM
  #57
But guessing and pretending to be mechanical engineers is fun.
Old Feb 25, 2003 | 10:01 PM
  #58
Yes- I suppose it could be fun to pretend- but not when you are the one an the receiving end of all the pretend conclusions about the results of this FEA. If you are going to do anything, do it right or dont bother.
Old Feb 26, 2003 | 12:46 AM
  #59
20FHK02's Avatar
2002 C230 Coupe
That's why I chose not to post any new results since I don't have the exact dimensions on the Kleemann and the ASP steel sleve alloy pulley. And since they were good there was no need to email them to Buellwinkle either, sorry.
The simulation was as real as it could be. I doubt a pulley manufacturer will go into this much detail as what I did, but I could be wrong.
The tensioner force was not even needed: the two belts are in exact opposite directions. So when spinning the most force will be on the outer SC belt, and at this moment there will be no force on the inner belt grooves (free surface). If the belt is not elongating, which I highly doubt it will, this means basically the outer SC belt grooves are radially fixed.
I admit the results I posted before were way too conservative because I didn't measure the actual washer diameter and assumed the diameter of the hub flange. But when I had a chance to measure it was only 1.85", which is about the size as the hub OD. So there were a lot of bending stress on the old analyses, which resulted in high stresses at the pulley-hub outer surface.
The new results showed no contact to the crank shaft except at the very end, so my last effort of trying to put contact elements to simulate the shaft was just for fun.
I can post the new results when I get to work tomorrow. Maybe Kleemann can compare to his results and see if they agree.
Keep in mind that they were ALL static analyses excluding vibration.
FHK
Old Feb 26, 2003 | 11:49 AM
  #60
20FHK02's Avatar
2002 C230 Coupe
Here you go
Both the stress intensity and axial stress on the aluminum are low.
Old Feb 26, 2003 | 12:00 PM
  #61
20FHK02's Avatar
2002 C230 Coupe
Axial stress
Old Feb 26, 2003 | 07:50 PM
  #62
20FHK02's Avatar
2002 C230 Coupe
Final One
Exaggerated deformed shape and axial stress distribution.
  #63
20FHK02's Avatar
2002 C230 Coupe
Just for fun
Old Feb 26, 2003 | 07:51 PM
  #64
20FHK02's Avatar
2002 C230 Coupe
Talking
I should send these to Lee, then he can say ASP also FEAed their pullies
Old Feb 26, 2003 | 07:58 PM
  #65
I have no clue what they mean but they look great. Maybe I'll have Lee make me a blue pulley with a red center. I'll have to lose the air filter box so that I can see it though.
Old Feb 26, 2003 | 11:31 PM
  #66
20FHK02's Avatar
2002 C230 Coupe
LOL! You just need a cone type K&N filter and route it toward the bottom
BTW, just put on the ASP pulley (the 5th one!!), so far so good. Hope it will hold up!
You have already rated this thread Rating: Thread Rating: 6 votes, 5.00 average.
