Hi Guys,
I had to remove steering wheel on my w203 coupe as my blinker stalk was faulty, however after refitting the wheel as soon as I started to drive the car now says 'ESP NOT AVAILABLE' can anyone help with this?
Cheers guys...
Cheers guys...
Cheers guys...
Did you disconnect the battery? Turn the wheel lock-to-lock to fix it.Originally Posted by 117
Hi Guys,I had to remove steering wheel on my w203 coupe as my blinker stalk was faulty, however after refitting the wheel as soon as I started to drive the car now says 'ESP NOT AVAILABLE' can anyone help with this?
Cheers guys...
Otherwise I'm not sure. Might be a steering angle sensor problem.
Did not disconnect the battery, and have tried turning the wheel lock to lock with engine running in park, is there anything else I could try, is it possible that there is a loose connection to the angle sensor?
Try sticking your old stalk back and see if it goes away.
Chances are though, it's a sync issue. Or maybe the dealer needs to clear a code.
if you turned the clock spring while it was out, you could have damaged it and it may need replacement.
Yes it did get turned slightly!!! I should have treated it more delicately but it was very stiff to remove! What kind of cost am I looking for a replacement....
