Please Help with coupe Coupe Trunk trim problem
Old Sep 3, 2009 | 07:04 PM
LAMB09's Avatar
2011 C63 AMG
Hey all
the black part around the sight-window and on top of the hatch above the third brake light is normally a glossy type black, for some reason this gloss is starting to come off and is like scuffed off. I will try to take a picture but it might be hard to see.
It seems like the clear coat is starting to come off If i had to describe it.
Has anyone else had this problem, if so were you able to fix it or is there something I can do?
If it keeps going this way it will look really bad and ugly.
Old Sep 3, 2009 | 07:26 PM
LinDenKid's Avatar
C230 coupe 2002
Originally Posted by LAMB09
Hey all
I have the same exact problem , the best you can do is to take it to a body shop , and have them fix it, its just a plastic part.
Old Sep 3, 2009 | 08:46 PM
XsuperbeeX's Avatar
C320 coupe
dont get it... pics?
Old Sep 3, 2009 | 10:07 PM
Nikic's Avatar
2005 C230K
I had the same exact problem when i owned the coupe.
I took it to the body shop and they fixed it up for me, cheap.
Like "LinDenKid" said its just the plastic part.
Old Sep 3, 2009 | 10:24 PM
LAMB09's Avatar
2011 C63 AMG
How did they fix it? Is it like a clear coat problem? Also what do you consider cheap so I know how much I should be quoted and not ripped off. It is primarily on the top, basically the whole top, and today a small circle on the left side next to the window after going to the car wash.
Old Sep 4, 2009 | 09:11 PM
MW_ATL's Avatar
'02 C230 Coupe (Me) '03 SLK320 6MT (Wife)
Mine is doing this in a few small areas too. I have always assumed that it required removing and replacing that polycarbonate little window piece, which I believe is epoxy-ish-ed to the hatch. I've just assumed it would be too expensive to worry with (yet).
Old Sep 5, 2009 | 01:49 AM
SunnyRayToronto's Avatar
2003 C230 Sports Coupe, Paprika Metallic Red, Auto, Pano, Leather
Maybe you can cover it with a little trunk lip spoiler that goes directly over that black plastic part,....
http://cgi.ebay.com/ebaymotors/Paint...Q5fAccessories
