if you break the glass does alarm go off?
2002 C230 K
Not in the US (at least for the Coupe and I imagine the lower-end C-sedans, not sure if this is the case with the C320), there are motion sensors available in Europe as an option.
- BT
- BT
2002 C230K
No it doesn't. My car was broken in (thru a window) and the alarm did nothing. They (thief) can't unlock the car from inside tho, pushing the unlock button does nothing.
2002 C230 K
- BT
C230 C-Coupe
But if they open the door the alarm will go off?
I have a work collegue who just had his 2002 Camry stolen. He claims the Camry has the same security coded key but that they were still able to hotwire the car. I told him that our keys were special but he seems to think the Camry security key work the same was as the C class.
I had thought that the only way to take the car was to either get a blank MB key or put the car on a flat bed. Is this true?
Thanks,
Nathan
Thanks,
Nathan
2002 C230K
Once, I left my windows open, and locked the car with my key from outside. Then I reached inside and pushed the unlock button and it did nothing. I'll have to try it again, maybe i didn't push hard enough.
2003 MB C230 coupe
i just went outside and did some experimenting. yes, i'm bored at work.
if you lock your car with your key and you press the unlock button on the center console (either from inside the car or through an open window ), nothing happens. but, if you lock the car with the key again, and open the door by pulling the door handle (all MB cars can be opened this way if they're locked ) either from inside the car or through an open windows, the alarms goes off until you unlock the car with the key (or until you put the key in the ignition probably, i didn't try this though, but i'd be willing to bet).
the alarm takes a few seconds to arm once the car has been locked. if you lock your car with the button on the center console, all bets are off cause the alarm isn't armed anyway.
so basically, someone can smash your windows and take whatever they want from inside the car. they just can't drive off or open the doors without the alarm sounding.
2002 C230 K
Originally posted by christian655321
has anyone had an aftermarket alarm installed?
- BT
Volvo V90 CC
Originally posted by Harris
Ummm....what happened if you lock yourself in the car? If you push the unlock button, the doors should be unlocked. Does the car know there is a false entry and disable the unlock button?
2001 C240
The car alarm went off while I was jacking the car up to change my front wheel. I suppose that protects the car from being towed off or having the wheels stolen.
have you guys seen BMW's double-locking system?
if the car is locked from the outside, there is NO way to open the doors short of ripping the doors out of its hinges.
2010 C300 4matic
guess i can call the dealer and inquiry about installing a eruo motion sensor or ask if it would even work.
Thanks,
Nathan
Thanks,
Nathan
Most likely it was reposed.
My 2 cents.
2002 C230K
what about the big, green, "help! i've been kidnapped" button? i mean, if they can break the rear windshield, they could remove the sight shield and push the button. question is, will that set off the alarm?
