w203 c230 nav
Old Oct 9, 2009 | 09:31 PM
c43-e55's Avatar
w203 c230 nav
i am trying to install a factory nav unit out of a 06 c55 into my 05 c230 what do i do for an antenna thanks
Old Oct 10, 2009 | 01:31 PM
samaritrey's Avatar
Super Moderator
THE C350
Search this has been mentioned way to many times.
Old Oct 10, 2009 | 04:18 PM
BF_JC230's Avatar
2005 w203 C230
Yup...Search The Forum.
Or - You can get an OEM WIS disc and it will tell you step by step what and how to do it...and you can print all of the pages out to bring to the shop!
But...Until you search...You need to...
1.) Locate an antenna - OEM, OEM with union or aftermarket >.45" thick with a BLUE Fakra end - OEM is bent down 90 degrees.
2.) Pull out instrument cluster and cluster hood
3.) Remove three t20 (or t25) screws from instrument panel frame
4.) Place antenna above instrument panel frame on top right (inboard)
5.) Run antenna cable to back of COMAND through center console center stack
STF, and good luck - Enjoy COMAND...you may need MOST Fiber Ring configuration - and will need STAR DAS to enable turn by turn in MFD.
Old Oct 12, 2009 | 02:18 AM
c43-e55's Avatar
where do i get antenna from dealer or aftermarket thanks
Old Oct 12, 2009 | 02:31 AM
maverik259's Avatar
05 C230K SS (sold), 06 C55 (sold), 08 Yamaha R1 (sold), 16 X5M
ebay
Old Oct 12, 2009 | 03:11 AM
W203E35's Avatar
2006 C350 Sport 6MT
