M271 Spark Plug- Dealer Gave Me Wrong Part?
MB Part# A 004 159 13 03 (NGK ILFR6A)
However, the one you actually were given NGK ILFR6A they have in stock. The tool on the site says it will fit 2004 C230 , so seems like you may be all set. Maybe the number changed.
on amazon these are $10.30 so your price wasn't too bad either.
Sounds like you're good to go from what I can find.
as long as the gap is correct and the heat range is within what you want to use they're fine.
I went to the dealer this morning, and this plug is the new dealer part that superceeds the original Bosch. OEM from the dealer now is this plug for the M271. I also went to Advance to double check, and they showed the Bosch F 6 MPP332 and the NGK ILFR6A for the M271.
