c230 Sedan sound system questions
ok guys...... after 19 days of owning her... i got tired of listening to the stock system with no bass. After taking a peek, it didn't look like a terrible headache, but wanted to hear if any of you had any difficulties... or any tricks that would save me any trouble
btw.. .where is the antenna? I wanted to tap into it for the remote(unless there is one at a factory amp in the trunk?). All I am doing is throwing 2 tens and using the line that runs to the sub in the trunk. Plus any specific place you found easy to ground in the trunk? Perhaps I am being lazy... but if i am prepared, I can finish everything tommorow night in an hour
and still have enough time for sleep.
Thanks guys!
![Wink](https://mbworld.org/forums/images/smilies/wink.gif)
Thanks guys!
C32
you want to use 2 10" subs from your factory amp?
i don't think that will be sufficent power. and... you will need some hi-low converter for the job. i don't think it will be a easy one.
Jerry
Jerry
no. I want to just use the line that runs to the sub in the trunk via line converter for an aftermarket amp. I haven't decided if i will run 4 or O gauge. I don't think i will do anything excessive anymore..... gotten that bug out of my system. But I would feel more comfy knowing that the O gauge was there and I wouldn't have to rewire later if i decided to do something. Anyhow.... is there a factory amp and where is it located?
