Possible Comand Purchase
Yep i know about the burning of the hackdvd... Not a huge deal.......I just like the look of the euro one a little better than I do with the one i have.
Wonder if there will be an issue with this... i know how finicky the stealerships can be...
There is one exception: If you have an open fiber loop in your car (meaning you have NO audio option - no cd changer, no satellite radio, no HK sound, no phone system). If you have NONE of those things and that comand unit is configured for a vehicle with an active fiber (MOST) loop then it may not boot up after you install it. This is not a problem as they dealer will simply have to additionally version code the comand unit for your MOST bus. You might want to ask OverDrive if the unit worked in his car without anything plugged into the MOST connectors on the back. It's really not a big deal either way.
It should not be an issue at a competent dealer. If it is I can find the official instructions on how to do it and you can take those to the dealer, but that really shouldn't be necessary.
So "coding" can fix either/both problems if needed?
CANbus high
CANBus low
CD Changer +
CD Changer -
D2B Wakeup
After those were hooked up.. Unit powered up and remained on.... (Some Command units will boot up but after 15 seconds shutdown since they can't detect the most system)
Now if you have a comand system doing this you can buy this
http://www.comandonline.co.uk/produc...cat=269&page=1
Right now im working on wiring for the speakers systems
