W203 Comand 2.0 install issues
I'm new here. I couldn't find an answer via the search, hence the new thread.
I have just retrofitted an A203 Comand 2.0 unit to my W203 (pre-facelift) C Class C220 CDI using an adapter cable from Comand Online. I've managed all the panels, connections and fitting okay but that still leaves me with a number of issues that I wasn't anticipating.
1) The Comand unit doesn't turn off with the ignition.
2) The steering wheel controls, e.g. volume, don't work.
3) The dashboard instrument cluster reads Audio ----, rather than Audio ON/OFF, etc.
4) the buttons on the Comand unit don't do what they say on them, e.g. the mute button opens the TV menu and the TV button mutes the sound, the zoom out (Minus sign button) accesses the CD menu, the i button (info) accesses the radio menu.
5) Whilst I can pick up satellites and my co-ordinates move as I drive, my position doesn't change on the map.
I have been into the diagnostics menu [MUTE]+[1]+[3] and done a reset but this has not fixed my problems (versions of my software/hardware are shown below).
Any advice would be appreciated.
Kind regards,
Bill
SW of Processors in Headunit
FIS: Mar 29 2001 18:25
SH: ---
SH Flash: ---
Corpo: Valid
DSP: 640000 130600
Navi BIOS 967.07.13:32:17
SW Version: REL__V15.12
Project: OMS_EU_R
FIS
HW version: 15.01
SW version: 13.01
Production date: 28.09.01
MB-Number: 2108205689
Product name:
Manufacturer: BOSCH
Diagnose ID: 0300
Serial number: 03258241
Version info
Decoder: V 5.21 Release
Head OMS_EU_R SH:2289 MCM:2289
Mask tool : 3.0d
SH Mask: V01.02 20-AUG-1998
F:V15.12 29-Mar-2001 OMS20_E
Comp.:Mar 29 2001 18:14:25
go on after 3 sec...
Corpo
Corpo: valid
SW version 30.01
SW date: 25.11.97
Variant: 01
DSP
SW date: 640000 130600
NAVI
HW version NAV: 1002
HW version CDROM: 06113
SW version BIOS: 967.07.13:32:17
SW version Diag: NO ROM
SW version NAV: 381.13.14:39:35
Version database: 384.16.10:47:18
Version map datas: 384.29.17:28:41
Version travel guide:
D2B
Serial No. SW vers. D2B-Proto.
Handy no no no
T-Aid no no no
SBS no no no
CDC 1226600 3002501 2.3
Sound no no no
D2B HIGH CONNECTION
PID 1 2 3 4
D2B-Address 00 00 00 00
Direction tx rx tx rx
open/closed lc lc lc lc
Con Status 00 00 00 00
CD-ROM
SW version 061.13V3.1
Infos
WARMSTART
Battery Voltage: 12.26V
TEL: Audio is not muted
GPS: 7Sat
Direction: forward
Speed: 0mph
TV
HW version: 00.00
SW vesion: 00.00
TMC
HW version: 42.98
SW version 42.11
SW MODULE
TCS TMC MANAGER
GSM Status: 14 E_TA_NOT_CONNECTED
GSM Status prev: 00 I_NO_STAUS
DIAG D2B Components
Pos Actual Config
000 1C8 1C8
001 190 000
OFF 000 000
OFF 000 000
OFF 000 000
I just found myself in the same boat (except that all the buttons work as they should)
If you figured out how to fix the problems, please share the information.
If you have the problems I have (except the transposed buttons) then it strongly suggests a Canbus problem. Double check the adapter is FULLY seated (the grey swing arm must be FULLY down before you push it in).
Hope that helps.
Bill
But the command work OK...anyone know what to do?
Ive got the 4 errors the main is 1780 so instrument clouster...
Regads
