Heather Malfunction (Need Help)
Old Dec 16, 2009 | 12:03 PM
KAPEH's Avatar
2001 C320
Exclamation Heather Malfunction (Need Help)
Hey.
I got 2001 C320. Recently i noticed that my heater blows hot air only when i am driving. In idle position air gets colder and as soon as i step on the gas pedal it starts to blow a hot air again. All climate control's functions are working properly. My mechanic changed the thermostat and flushed the heater radiator, but the problem still exist. Can anyone please help me? Any ideas? Any suggestions? I'll greatly appreciate any help.
Old Dec 16, 2009 | 02:30 PM
acr2001's Avatar
2012 C300 4Matic
Check your auxiliary coolant pump. If you put the vehicle in run and turn the heat on without the engine running (or if you have REST which I think you do) you should hear that pump running. If not it is probably shot or has a bad connection.
http://media.photobucket.com/image/m...7/DSC03374.jpg The pump is the cylindrical object attached to the coolant reservoir.
Old Dec 16, 2009 | 03:31 PM
jogger's Avatar
02 S500
if Heather is malfunctioning perhaps you should get counseling
Old Dec 16, 2009 | 05:37 PM
samaritrey's Avatar
Super Moderator
THE C350
Old Dec 16, 2009 | 05:47 PM
KAPEH's Avatar
2001 C320
I'll get that checked and let you know. Thanks acr2001.
Old Dec 16, 2009 | 06:05 PM
samaritrey's Avatar
Super Moderator
THE C350
easy to test with the rest feature turn it on. pop the hood and feel or listen to see if it works.
