Kleemann C32K Performance
Old Mar 11, 2003 | 04:29 PM
alee337's Avatar
Does anyone here have the Kompressor engine from Kleeman on their W203?? I am thinking about putting one on my 320, but want to make sure the performance I get is ALMOST equal to that of a C32. Any specs on 1/4 mile or 0-60 times?
Regards,
Alan
Old Mar 11, 2003 | 04:55 PM
AndrewK's Avatar
Audi S4
I think evosport claims 330 hp for the 3.2 w/ Kleemann kompressor. Look HERE for a more detailed look at Kleemann supercharger applications.
Old Mar 11, 2003 | 06:19 PM
Hank's Avatar
Re: Kleemann C32K Performance
It's far from it. C32 engine is designed for and operated under more boost. I'm sure evosport can describe to you the dyno results of a customer's white C320 (from Mexico). I'm sure they can't show you the actual dyno cuz they probably would need the customer's consent.
Old Mar 11, 2003 | 07:09 PM
Cory @ Kleemann's Avatar
Former Vendor of MBWorld
Regards,
Alan
Straight from Car and Driver Magazine:
2002 C32 K- 330HP 325 lbs/ft.
0-60- 6.0 seconds
0-100- 15.4 seconds
0-130- 27.8 seconds
Street start 5-60- 6.4 seconds
Standing 1/4 mile- 14.5@97 mph
Top Speed- 134
Braking 70-0- 167 Feet (stock brakes)
Roadholding (300 ft. dia. skidpad)- .80 g (Kleemann Suspension)
Now you can compare to the C32 on the Mercedes Website.
Old Mar 11, 2003 | 07:24 PM
alee337's Avatar
Thanks for the info guys. =)
Hmmm....my stock C320 (auto) is SUPPOSEDLY running a 6.9 from 0-60 (as stated on MBusa.com).
I can't justify spending almost 5 figures on a supercharger to get 330bhp and run 6.0 flat. Just seems a little odd to me that the power increase here (215hp vs. 330hp) does not create a more dramatic change in speed performance.
Oh well...guess I'll have to wait till my W211AMG arrives and waste money on that instead.
Alan
Old Mar 11, 2003 | 07:34 PM
Silver_Lana's Avatar
Re: Re: Kleemann C32K Performance
0-60- 6.0 seconds
0-100- 15.4 seconds
0-130- 27.8 seconds
Top Speed- 134
Wow.... those numbers seem really off for a 115 HP bump in power. I was expecting much more. :sad:
Old Mar 11, 2003 | 07:40 PM
Alan
Also keep in mind that MB's numbers are pretty conservative. I'd say the C320 goes 0-60 in about 6.6 - 6.7 seconds and that just makes me warier of those numbers for the upgrade.
Might as well save the $10k and get a C32 //AMG or like you said... save up for the W211 E55 //AMG.
Old Mar 11, 2003 | 08:43 PM
CHATMANR's Avatar
Veteran: Navy
From: From Oxnard; living in Ocean View Hills, San Diego, CA
'01 C320 SS
Re: Re: Re: Kleemann C32K Performance
IMHO,
if you've experienced various vehicles with different h.p.; adding 100h.p. to your setup WILL knock off about 1 sec. of YOUR 0-60 times...if you can hook up without assistance from ESP....
1985 Toy Supra [Thorley headers, HKS P-flow, Exh] 210hp
1988 Toy Supra [HKS Stage 3 [circa 1990] 325hp@22psi
1994 Honda Civic EX Turbo [Rytek/DPR] 280hp
1999 Honda Civic EX [Stocker]
Old Mar 11, 2003 | 10:01 PM
jswedberg's Avatar
C32 AMG
I've noticed that, in several magazines - they would compare "stock" to "modified", and the 0-60 times would not drop as much as I would have thought, given the horsepower increase.
I guess there must be more to it than just power?
Old Mar 11, 2003 | 10:53 PM
It would seem so since you would expect the C32K to be at least 5.5seconds in a 0-60 sprint.
Old Mar 11, 2003 | 11:33 PM
Brandon @ Kleemann's Avatar
Yes, you are right. For example if a 200hp car does 0-60 in 10 seconds, making it have 400hp would not equate to a 5 second 0-60 time (if all other htings remained the same). There is a non-linear relationship of power to acceleration if all other things are equal.
Which brings me to my second point- the C32K VS C32AMG scenario. The KLEEMANN makes 20 less HP and almost 50 lb/ft less power than the AMG. That alone would make things pretty even- but there is more going on. AMG utilizes a much faster shifting program in the EGS controller than a standard C class. Upshifts happen 33% faster at a higher RPM than a standard C class, more torque through the entire rev range and -BOOM- you can drop a second in 0-60 easily.
Our system is close but not the same- it represents the opportunity for people who have chassis that there is no AMG option for to have a better performing car (E320-4matic, ML320 , G320, CLK320, etc). Remember that our V6 system was available almost two years before AMG was available to anyone. Odd too, that AMG's system is so close to our own.
I will be the first to admit that if you had to choose between a C320 with our SC and a C32AMG, the C32AMG is the obvious choice.
Old Mar 11, 2003 | 11:44 PM
dswildfire's Avatar
2002 C230K
yeah, the closest thing there is to a relationship that you can do in your head is, for every time you double the power of the car, shave two seconds off the quarter mile. it works fairly well, but gets inaccurate once you start hitting higher hp numbers.
Old Mar 12, 2003 | 01:07 AM
Fresh's Avatar
I brought up a topic just like this about a month ago and got similar responses, saying take c32 over kleeman c32k. I thought it was unusual that the c32 was a whole second faster with such similar power ratings but i guess a difference of 50 in torque is white a lot. Also amg did other modifications besides the supercharger such as including certain lightweight parts and the transmission is much better.
Old Mar 12, 2003 | 11:46 AM
jswedberg's Avatar
C32 AMG
The point I was trying to make was that often, in car magazines, a "modified" car (say for example a 450 hp Supra) will be only a couple of tenths faster than a stock one. I've always wondered if the engine REALLY put out the power the tuner said, or if other factors (wheel slip, etc) were involved. Factory cars seem to improve with horsepower they way one would expect (C240 vs. C320 vs. C32, for example)
I don't have the equation with me right now (I'm sure someone can find it? It was in Road & Track a couple of years ago) but there is a quick-and-dirty formula for estimating quarter-mile time sbased on horsepower, weight, etc.
It comes down to horsepower and acceleration are related in a square relationship - twice the horsepower will give you .707 (inverse square root of 2) the quarter mile time.
Of course, it's really rough, doesn't take into account drag, etc.
