headlight bulb removal
2007 C230/2007 A3 S-Line/2004 20g STi
How is the bulb removed? I got past the cap, but does it twist and then pull out? or pull out straight?
^ Yup, twist the ring then pull it out. Note the indents of the lamp surround as you pull the old bulb out so you can align the new one the same way. If you do it right it takes less than 5 minutes / pair. But if you do not align the indents it will make life very difficult.
