20mm H&R DRAs for c55 wheels on the rear?
Old Dec 30, 2009 | 09:50 AM
jimsterli's Avatar
2004 c230k
I was thinking about the 20mm H&R DRAs that bolt onto the hub so the stock lugbolts can be used. I am not comfortable with getting longer lugbolts.
http://www.tunersdepot.com/Wheels/Sp...9.html?yy=2004
Will the tire rub against the fender with this setup? Advan thinks that it will without rolling the fenders.
As mentioned, c55 rear wheels are mounted on my 2004k sedan. Planning to keep the 245/35/18 tires.
I have been STFF and mostly people are using spacers with aftermarket wheels.
Old Dec 30, 2009 | 10:15 AM
advans's Avatar
C55 ///AMG, 535xi
Jim,
You'll need longer bolts. You won't rub if you roll the fenders
