05 C230K Brake Pad Sensor Question.
2005 MB C230 Kompressor
I changed the brake pads and the front rotors in my car today. the shop we got the parts from told me that there will be a sensor in the front and back. well i started on the right rear brake, and noticed the pad had the notch for the sensor but my friend and i couldn't find the sensor. so im asking, is there a sensor in the rear of the car?
i found the sensor easily on the front brakes, but rear showed no sign of a sensor ever being there/connected.
2012 C300 4Matic
I'm not sure how specific this is. They changed the number of and location of the sensors so many times that it probably varies by model year. If you're not getting a brake wear warning you don't have to worry about replacing the other sensors. If they were damaged or disconnected you would be getting a warning.
