Cig lighter stuck?
Old Jan 17, 2010 | 11:19 PM
peedi's Avatar
2003 C320 4matic
Cig lighter stuck?
i drive a 03 c320 and was wondering is there a button to press to pop the cig lighter out? I press it down and nothing happens. help?
Old Jan 18, 2010 | 12:03 AM
howardyudoing's Avatar
07 c230 sport
idk but cig lighters should pop back up when it gets hot enough, then you just pull it out. i'm not sure how long it takes to heat up though. maybe try pulling it out after 30 seconds or so? good luck
Old Jan 18, 2010 | 01:11 AM
peedi's Avatar
2003 C320 4matic
well it seems that i doesn't even want to be pushed down lol
Old Jan 18, 2010 | 04:03 AM
acr2001's Avatar
2012 C300 4Matic
Probably a blown fuse. If the cig lighter isn't getting power it isn't going to heat up and pop out.
If it is getting power and it's stuck in there, then I assume that would (hopefully) cause the fuse to blow.... otherwise I'm sure you would have noticed the smoke by now
Old Jan 18, 2010 | 04:05 AM
Racin_fool's Avatar
2008 E63 wagon (1 of 62)
more than likely the fuse is popped for this.. Check under the hood on the drivers side towards the firewall.. In the fuse box there is a blue 15amp fuse in position number 52 if i remember correctly. Unless something is physically stuck or causing it to stick, this will activate the lighter and cause it to pop out again.
