Testing Racetec intercooler
Old Mar 15, 2003 | 06:00 PM
Buellwinkle's Avatar
Here's a new intercooler that we installed today. Unfortunately because of the heavy rains and cool weather I haven't been able to push the limits of the intercooler.
It bolts up nicely using existing bolts and doesn't rub up against anything, nice fit all the way around.
Old Mar 15, 2003 | 06:09 PM
Matt230K's Avatar
2010 C300 4matic
How come this is the first time we are hearing about this? If everything goes well, any idea how much they will sell for??
Old Mar 15, 2003 | 06:15 PM
Racetec told me the target price is expected to be about $650-$700. I did mention the word "Group Buy" and he said that depending on how many are in the group would determine the price. Currently Racetec intercoolers are a premier intercooler for Audis.
Old Mar 15, 2003 | 07:08 PM
SiLvaC32's Avatar
C32
wow.... looks good!
Old Mar 15, 2003 | 08:52 PM
QC1's Avatar
QC1
C230 Coupe
I would be interested in a group buy, let us know Buel
Old Mar 15, 2003 | 09:47 PM
nukblazi's Avatar
So what are the differences between this one and the Renntech?
Old Mar 15, 2003 | 10:34 PM
First off it's $300-350 less expensive but that wouldn't have mattered to me that much. It's smaller, only about 60% larger than stock vs. Rennech's 125% larger than stock. The core is made in Germany and is supposed to be one of the best flowing cores out there. The end tanks are welded on the sides instead of the corners where the highest pressure is and only requires 2 welds instead of 4. All the sides in the end tank are angled towards the piping which is mandrel bent and a smooth curve vs. having 3 sides square and 1 angles like a wedge with a pipe coming out the side instead of the end. Last but not least, installation is a little easier because it uses existing mount points instead of having to drill holes in your car.
The goal is to provide ample cooling, reduce pressure loss and airflow turbulance. Not that the Renntech/Spearco unit is bad, I just feel this design is better. Of course I won't know for sure until I do some testing, it's just the streets are a little flooded right now, yes I know, it never rains in California.
Old Mar 15, 2003 | 10:49 PM
Matt230K's Avatar
2010 C300 4matic
Sounds like a pretty good intercooler despite the smaller size. I can't believe that it fits so much better and probably flows better than the Renntech. And they call themselves an MB tuner. For the prices that they charge, they could have at least done a little more work on it.
Renntech builds an intercooler strictly for this car, but yet you have to drill new holes to mount it. But yet this aftermarket many-brand tuner can make one that fits perfect. Way to go Renntech.
Old Apr 3, 2003 | 08:15 PM
czachari's Avatar
2003 C230
Gains? Does it void the warranty?
Also, will they make one for the 1.8L?
I may be interested in a group buy.
cz
Old Apr 3, 2003 | 09:41 PM
Re: Gains? Does it void the warranty?
cz
A more efficient IC doesn't give you gains when cold but prevents you from losing power when the factory IC would have gotten heatsoaked. For example, on a sunny 75F degree day intake air temp (IAT) with the factory IC after just one 0-80 run from cold heats up the IC to about 118F, keep doing it and it will heat up to 156F after about 2-3 runs and you'll lose 10-15 HP, with the Racetec, it maxed out at about 118F after four back to back 0-80 runs preventing this loss. This is because of 2 reasons, 1) cooler air is denser and has more oxygen, 2) the IAT sensor is used by the ECU to determine timing. the hotter it reads the more it wants to retard timing to prevent pinging (actually on some cars people put resistors on the IAT sensor to trick it into believing it's cooler than it is so it can advance timing).
The 1.8L coupe uses the same IC as the 2.3L, same installation. The sedan may require a different mount point but I'm sure they can make the necessary brackets if someone wanted it for a sedan.
Old Apr 3, 2003 | 10:35 PM
Outland's Avatar
2002 C230 Coupe(M111)
Given the much higher boost of the 1.8, a larger intercooler should show some HP gain even when cool.
Old Apr 3, 2003 | 10:38 PM
adamrs80's Avatar
2004 SLK Special Edition
Does Racetech have a website? Do we know an exact price yet?
Old Apr 4, 2003 | 12:29 AM
Sorry, I don't have more info. Write to the owner, Russ at gshock@charter.net and see when he'll be ready. I think he was waiting on custom couplers to be made. It's a strange coupler on our cars because it's 2 3/4" on the outside diameter and about a 2" inside diameter because it's double walled but only on the coupling, not the entire pipe. They used to have a website but they mainly sell through dealers that have websites. He does have some other really interesting intercoolers that flow top to bottom in a Z shape up and down from start to end. He didn't think that design would work in our cars because it's designed for higher boost applications.
Old Apr 4, 2003 | 01:07 PM
tberry's Avatar
2002 C230 Coupe Black/Charcoal C5 C7 Auto
Thanks Buell, I know its not cheap but any new dyno#s? I'm pretty much gonna get it (gotta get rid of the Renntech spoiler first ) Where did you get your ITG filter by the....didnt realize it made that difference and figure what the heck....summer is coming in TX and aint gonna be pretty
Old Apr 4, 2003 | 02:56 PM
ITG AirFilter Source
Call Josh MacMurray at 801 886-2185. They have a website, just don't remember it now. I think it was about $60 and takes about 2-3 weeks to get to you from the UK as they are made to order.
Old Apr 4, 2003 | 02:58 PM
QC1's Avatar
QC1
C230 Coupe
I contacted Evosports for the ITG filter and they said that the ITG filter actually loses HP. I thought to believe him because its not often you hear someone whos selling claiming that the product is not that good
Old Apr 4, 2003 | 06:41 PM
Outland's Avatar
Unless of course its not a product that they sell.
Unusual that a free flowing air cleaner would cause a power loss.
Old Apr 4, 2003 | 08:31 PM
They do one test on a totally different car, the C32 and find it loses power, what can I say. I also tried buying from them to support the forum, first they said one month and then they told me what they told you. I went to their shop and showed me the airbox with the K&N from a C32 and yes, it does seem to block a large portion of the inlet hole. I called every possible dealer in the country that ITG in the UK led me to, actually they recommended Evosport in the first place. The dealer above, a BMW tuning shop told me that they would get them and actually stocked them for a while and they still might or you'll have to wait for them to come from the UK.
I did a dyno on a totally stock C230 and got 1 HP and on a pulleyed car I got 3+ HP at the wheels consistantly on 2 different cars. I got about 5-6HP with no filter but that won't make for happy engine. So for me the gain is there and usable. The K&N also pulls in 3 HP on a pulleyed car and I owned both but gave away the K&N, just believe in the ITG a little more but both will give you gains and I'm sure both are good lifetime filters. What was surprising is the gain came across the rev range, not just at high RPM like I was expecting.
