Sticking Hatch Release
Old Feb 9, 2010 | 10:36 AM
TNblkc230wz's Avatar
C320 Coupe
I'm selling my C320 and I'd like to fix the only two mechanical issues it has.
1. When it is cold (below 45 degrees), the rear hatch release sticks/doesn't work. The inside emergency release will still work, but the out side release does not. When it warms up, everything is normal. Is there something that needs adjustment or lubricated?
2. Again, when cold, the e-brake pedal will not release all the way. I can lift it with my foot and it releases fine. When it is above 45 degrees, it works fine as well. Any ideas.
Old Feb 9, 2010 | 11:09 AM
03MBC320's Avatar
2003 C320 4Matic
i had the same problem with my trunk release too, i sprayed it pretty liberally with some WD-40 and it stopped sticking (mine was sticking as if someone was holding the latch down to open it the whole time, i'd have to pry my finger nail behind it, pop it out, then pull it to open the trunk, i popped it into its normal place as i said with my fingernail, then soaked it with WD-40 and sat there with a towel wiping off the drips lol)
and also had the same thing with the e-brake actually. When i went in for my Service B i told them about it and they said that they tightened it/fixed it, but a couple days later it started sticking again too, and i haven't found a way to get it to release smoothly since then
Old Feb 9, 2010 | 03:16 PM
samaritrey's Avatar
Super Moderator
THE C350
there is a thread about the e brake and how to adjust it and lubricate it. if is for a sedan though so don't know if that will help you.
Old Feb 9, 2010 | 04:05 PM
C320 Coupe
I have searched, but can't find anything.
Old Feb 10, 2010 | 07:47 AM
KillerPancake's Avatar
2005 C230K coupe
For the e-brake issue, the problem is most likely under the back seat. Pull up the seat bottoms and remove the piece of carpet. Remove the access cover that's right between the two seats. You'll see the part that allows you to adjust e-brake cable tension and splits the cable from one to the front of the car, to two (one for each wheel). The splitter part has a pivot point that needs to be able to move. This gets rusty and stuck and prevents the e-brake from releasing without a little help. Lubricate the hell out of it and work it back and forth until it moves freely and this should solve the issue for you.
Old Feb 10, 2010 | 05:21 PM
C320 Coupe
That sounds easy enough. Thanks!!!
Old Feb 13, 2010 | 01:10 PM
C320 Coupe
Cleaning the ebrake cable fixed the problem. I also found the problem with the hatch. The electrical switch came loose from the handle. Everything works now.
