Official C-Class Picture Thread
#6356
07 C230 (sold) 2009 E63 AMG (SOLD), 2015 E 63 AMG S
#6357
1st Post, 1st Mercedes. I've had it about 2 weeks. So far I've purchased new wheels, added a Kenwood nav and all new speakers. I pulled the rear shelf and died it back to black (sun faded to purple).
Trying to figure out what to do next.
#6358
06 C230 SS 6spd
looks good, do a tint on it and remove the side markers and get some euro impact strips, cf lip, set of xenon headlights or depo projects with HID kit. Change your brake pads to Akebono if you dont want them wheels getting so dirty from brake dust if you haven't, maybe a c32 rear deck lid.
#6364
W203 C200 Kompressor
![Smile](https://mbworld.org/forums/images/icons/icon7.gif)
#6370
#6371
oh awesome well mine are nearly the same as the H&R but i told them to make them a bit shorter and stiffer, i may recommend cut half a coil on the rear, will give it a nice look and also if you haven't fitted the front cut half a coil infront as well it wont harm anything as the springs are very stiff and will give it that coil over look and will look lower. thats my opinion anyway and the ride is the same no difference at all but a little bit harsher as you usually get with lowering springs.. hope it helps and good luck
#6373
06 C230 SS 6spd
h&r actually drop the rears a lot lower than the front. most cut the fronts a coil accomodate the rear being so low or will get thicker rear pads to lift the back end up a little.
#6374
#6375
