INTERMITTENT NO POWER
Old Feb 16, 2010 | 07:20 AM
SWANEPGA's Avatar
2001 c320
Exclamation INTERMITTENT NO POWER
MY C320 W203 HAS AN INTERMITTENT PROBLEM !!!
IT WILL BE FINE FOR MONTHS SOMETIMES AND THEN SUDDENLY LOOSE POWER CREEP ALONG AND DIE. IT WILL IMMEDIATELY RESTART AND GO AGAIN. I HAVE REPLACED CRANK SENSOR , DISABLE LAMDA PROBES AND STILL SAME PROBLEM . IT SHOWS NO FAULTS ON THE STAR MACHINE AND ENGINE MANAGMENT LIGHT DOES NOT GO ON
hELP!!!!!!!!!!!!!!!!!
Old Feb 16, 2010 | 02:42 PM
krisv420's Avatar
02 C320 Sedan
Welcome to the forums.. First don't type in all caps.. Second that sucks..
Old Feb 17, 2010 | 11:20 PM
mleskovar's Avatar
'17 Jaguar XF
How many miles on your car? Have you replaced the fuel filter yet?
Old Feb 18, 2010 | 01:54 AM
SWANEPGA's Avatar
2001 c320
Hi
130.000 km on the clock , fuel filter replaced 5000 km ago , crank sensor replaced +- 10,000 km ago . throttle housing cleaned by dealer 10.000 km ago - no faults on star machine ----driving me nuts
Old Feb 18, 2010 | 02:17 AM
TemjinX2's Avatar
03 g35 coupe...........02 c32 Sold
Old Feb 18, 2010 | 12:04 PM
mleskovar's Avatar
'17 Jaguar XF
Why 'disable the lamda probes'....just curious. My guess is fuel pump. Some of the early C class had fuel pump problems that showed up as shaky idle and motor dying with no error codes. Does it just die or gradually lose power and then die?
Old Feb 27, 2010 | 02:38 AM
SWANEPGA's Avatar
2001 c320
lamda probes showed open circuit - so i just tried it ------not fuel pump as this only happen maybe once in 6 months - it is now more than a month since the last time it happened. it loses power gradually and then die - can be restarted immediatly again
