Advice for service work
I brought my car in for a regular service today and received a call back regarding a few problems they found. First, my head gasket is leaking and I was quoted +/- $500 for the job. My cam sensors are also leaking and replacement, pigtails and wire/engine cleaning would cost $450. Even though there is a recall, my VIN does not fall into the years so I am taking that one in the rear. Also, my rear sway bar bushings are worn ($400) and both rear knuckle assemblies (?) need replacing +/- $600.
I was a little surprised with the $2000 number, but obviously the oil leaks are problems that need to be addressed pretty quickly. The ride quality is suffering from the worn rear suspension components, so those too need to be replaced ASAP.
My question is, what would you recommend i get done first, and should I have any of this done at the dealer? I have no problem using an indy, but I just want to make sure I get the right part numbers for everything so the job gets done right. Does anyone know of roundabout pricing for any of these jobs, with parts, at an indy shop? Thanks in advance!!!
I changed my head gasket with individual mechanics, he charged me $200 for the labor and parts.
I think for the rear sway bar bushing you can change by yourself, just get the parts from dealer or website. Have you search in forum about DIY rear sway bar bushing?
Usually if your not burning coolant or oil, then its not a head gasket. I would wait for the pressure test first before you spend hundreds to thousands of dollars.
The pressure test sounds like a good idea before taking the head off. should i have mercedes do that or take it to an indy? It doesnt appear to have a lot of oil leaking out, just some buildup over time. the cam sensor leak probably makes it look worse than it really is.
The sway bar bushings im not too concerned with because they arent cracked or anything. Just worn and have some play. I know i can get those replaced cheap and can probably DIY.
But the rear assemblies seem like something to be replaced quickly, as my rear end is hopping out. ill check on parts when im at the dealer and let you know more after speaking with my SA.
Im thinking of having the dealer do the cam sensors and get them all cleaned up, and get an alignment done. After that ill take it to an indy to deal with the rear assemblies and check the head gasket. Hopefully that will shave off some $$$ from the $2000 MB quote.
