HID Question!
Old Apr 13, 2010 | 12:25 AM
benz111's Avatar
2002 c230K W203
HID Question!
Hi guys,
I have searched and didnt seem to find an answer.
I know that if i was to put a HID kit in my w203 the error codes would come up and the lights will eithet not work at all or jsut flash.
I know that the Srock Halogens run at 55w and the problem happens when you plug in 35w hids.
If i was to put 55w Hid's would they work ok? Because the issue only happens when you plug in a 35w bulb into a system that runs 55w and higher current etc...
Thanks.
Old Apr 13, 2010 | 01:20 AM
bdgdl08's Avatar
1999 CLK320 (sold), 2007 C230 SS (gone), 2000 Grand Marquis, 2011 CR-Z, stay tuned...
No, the current pull is still different from stock. I have 55w and they didn't work. DDM has error eliminators for about $20 for the pair. I bought them when I bought my HIDs from them. I tried without first, but had no luck. I later got Xenon set to present on my car so that I could run my DRLs, and all is fine, now.
Old Apr 13, 2010 | 01:27 AM
benz111's Avatar
2002 c230K W203
Thanks for the quick reply.
Old Apr 13, 2010 | 01:32 AM
bdgdl08's Avatar
No problem, just happened to check at the right time.
Old Apr 13, 2010 | 02:11 AM
w203sport's Avatar
2006 c230 Sport
i bought an HID kit from the group buy HIDextra.com. i didnt have to set xenon=present and they send you a free capacitor/resister whatever it is to stop the flickering. No error message. works great
Old Apr 13, 2010 | 05:45 AM
laneshift's Avatar
C240
I bought three kits from them for three different cars.. never got one. Did you request it?
I just went to the dealer and got my xenon=present setting.
Old Apr 13, 2010 | 11:51 AM
jcnash's Avatar
2002 Mercedes Benz C230 Coupe
How much did they charge you to get Xenon = Present?
Old Apr 13, 2010 | 12:04 PM
DrgnflyZ28's Avatar
2007 W203 SS
+1 Bump
Old Apr 13, 2010 | 03:48 PM
bdgdl08's Avatar
My indy shop did it for not. I was told that, if it took less than 10-15 minutes to do, that it would be free. It takes about 30 seconds if you give them instructions.
Old Apr 13, 2010 | 05:00 PM
w203sport's Avatar
2006 c230 Sport
if you right down on the special instructions or notes whatever section it is, you write what car the HID kit is going on and if it requires the capacitor/resistor they will send it to you at no charge. but if they dont know what kinda car it's going on they dont know if you need it or not so they assume you dont. So write down the car it's going on so they can see if you need it.
Old Apr 13, 2010 | 10:34 PM
aac85's Avatar
2005 c320 4matic
yep, it quite literally takes 30 seconds.
the question is.... which of your local dealerships are willing to do so. most are reluctant to do it for you since its aftermarket. even if they do, they charge you an arm and a leg. $75-150.
best to do it through an indy shop.
Old Apr 15, 2010 | 02:12 AM
ROLLNNN's Avatar
2005 CLK320 Vert & 2005 CLK55 AMG
I've had the ddm HID's 55w with error canceler for a little over a year. I set my xenons to present a couple months ago. but tonight when i turned my lights on my drivers side would flicker really fast like 5 times then stop, then do it again and stop after about a 4th time of flickering it wouldnt turn on at all? Anyone know whats wrong?
Old Apr 15, 2010 | 02:20 AM
bdgdl08's Avatar
Sounds like the bulb is going... DDM has a lifetime warranty, they'll send you new bulbs if you contact them. Matt has had this problem twice, and they sent him bulbs in matching pairs - free!
Old Apr 15, 2010 | 07:53 AM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
Drew is right, contact DDM and they'll send you a new pair of bulbs for just shipping charges.
Old Apr 15, 2010 | 02:35 PM
ROLLNNN's Avatar
Cool thanks guys. ill give them a call today. I thought these things were made to last more than a year... DDM opened up a shop in Huntington Beach, hopefully i can just go down there and pick them up...
