Wheel & Tire Question
Will 19" rims fit with no modification?
Here are the tire sizes.
Front-255/35ZR19
Rear-285/30ZR19
Is there enough room for the rims and tires to fit?
I tried searching but didn't get a clear answer and can't seem to find the correct info online.
thank you
He said they are off of a 06 SL500
Foose DF-5s
He doesn't know the offset and can only provide me with the tire size.
Front-255/35ZR19
Rear-285/30ZR19
thank you
If you have the Sport Package, you have the big Brembo front brakes, and you will need a rim offset of 35 or less to fit the fronts w/o having to use spacers, but you will have to come down on the tire size. The largest front tire size I have seen mounted on front on your car type is a 235 but even that is very tight so I would suggest continued research and try to find some from a seller with knowledge on fitment for your car. MB's have alot of aftermarket rim selections, but going too far one way or the other can compromise handling and ride quality, and you want to buy from someone who knows what they are talking about. Good luck
FYI-
Stock tires/rims for your car-
17" x 7.5" front rims, 225 45 17 tires with a factory 36ET (Five spoke hyper silver rims)
17" x 8.5 rear rims, 245 40 17 tires with a factory 34 ET (Five spoke hyper silver rims)
5 x 112mm bolt pattern
66.6mm center bore hub
The search continues.
Thanks again for the constructive comments.
