Black Wheels--HOW TO?
I was driving around in the bay area the other day and saw a W203 just like mine...black ext /int, etc, however had the wheels in black.
I am assuming these were not available direct from MBUSA at the time, so I am wondering how he got them in black?
Do most of you recommend those painting kits?
I found some at rimpainter.com
I really want mine in black. Please help! is there a shop in CA that does this professionally? I really don't feel like buying new wheels. I like the ones that are on there. I just want them in black
Thanks for any advice
1) You will want to sand all of your rim or rims with a 150 grit sand paper. (Be sure to get all corners)
2) Spray with primer.
3) Repeat steps one and two 4-5 times.
4) Next, you will want to tape off your tire. Or you can go to a local tire shop and ask to get it dismounted from your rim.
6) Spray with your choice of spray paint.
7) Finish it off with clear coat. \
(Adding lines like time attack rims will have additoinal steps.)
You wont need clear coat with DupliColor wheel pain.
http://www.youtube.com/watch?v=d0sl_...eature=related
So powder coating doesn't give me the option to have them look more on the glossy side, or am I wrong?
Also, does anyone know of a good place that powder coats in the Northern Cal area? I'm about an hour from the bay area.
Also check out the "Wagons Ho..." thread. I am going to post a few more in that thread here in a few. Cheers, Greg
