Spacers/Blots
https://mbworld.org/forums/wheels-ti...8-5-9-5-a.html
He is local and I tired the other day and I am going to need spacers.
If I get the 3mm or 5mm should I get some longer bolts or will I be fine. I am a total noob and want to make sure I get the right stuff. I asked in another thread but no response and searching did not get me anywhere. So I thought I would start a new thread and get my answer right away.
You can merge once I find my answer thanks!
Will 3-5 mm's be enough? I can't tell by the curvature of the spokes, but you may need a bit more, like 7 to push it out to +28mm. I would get extended lugs if they're 7, but with 3-5 you maybe fine. But even then the safest thing to do is to get longer bolts, even if it's just a little extended.
