Thinks to check...
Today I decided to check TCU connectors, guess what, found oil in the harness, I took the tcu out, clean the connectors, and the harness.
What else do I need to check on the tranny, what other connectors? I'm going to check TCU for codes, CEL its not on.
Tranny problems I see so far, its when it change from 2nd to 1st, its feels hard randomly...
BTW car is.. C230 2005 5speed
Thanks.
I have the same year make as yours so did you find anything else out?
Just clean it real good and you should be okay.
TCU is pretty much on the lowest part of the car, so fluid can't go anywhere else.
Unlike leaky cam magnet that gravity can pull oil down to O2 sensors.
