Gear shifter boot
Old May 11, 2010 | 12:35 PM
la103064's Avatar
Mercedes Benz C320
Gear shifter boot
How do you replace a gear shifter boot. Mine is torn and I was wondering if there are any other after market alternatives besides replacing the boot itself?? Help!
Old May 11, 2010 | 12:50 PM
tommy's Avatar
2004 Civic Si. FWD for the Win!
Year and slushbox or manual transmission identification would help with the answer.
Generally, unless you want to do a bit of fabrication and/or gluework, OEM is the safest bet, unfortunately. Though it may be pretty expensive - some models don't have a separate boot, and you'd have to buy the entire shift assembly in total.
Old May 11, 2010 | 01:24 PM
la103064's Avatar
Mercedes Benz C320
Gear Shifter Boot
I have a 01 C320 automatic. I saw some used OEM shifter with boot on ebay for $100.00. Unfortunately, it was a black leather boot and not gray. I may have to resort to the glue repair. Thanks for the help.
Old May 14, 2010 | 08:40 PM
dj emil's Avatar
C230 kompressor coupe
hey wud up, been doing some ebay research and came across this
item. good luck
http://cgi.ebay.com/MERCEDES-W203-C-...item5633b2b3e8
