Sticking Trunk Release Handle
My trunk latch handle is obviously grimed up to the point that it sticks in the open position when you squeeze it to open the trunk. In order to get it to return after squeezing, you literally have to wedge your fingernail behind the handle and give it a fairly substantial flick. Sometimes it opens, and sometimes you lose a piece of your fingernail and say naughty words in front of the neighbors kids.
The only thread I found on this was one that suggested flooding the handle with WD-40 and wiping it off. To me, that sounds like a messy shortcut that's going to work for about 2 days. I'd rather take the assembly off, clean it properly and re-lube it so I don't have to worry about it any more, but I can't figure out how to get to the latch assembly. I just replaced my drivers door handle in about 30 minutes...I can't imagine this would be much more of a job than that.
If anyone has done this, I'd really love to know how. The car is great...really nothing major in all these years...I'm just going a little Jack Nicholson on this one. Thanks.
problem solved =)
edit, wow, just actually read your post and i can see the method i did is exactly what you said you didnt want to do lol.. so i guess if you give up removing the handle, you've got instructions for the cheap messy shortcut, you said part of the reason you didnt want to do that was because it would only last 2 days, but mine hasnt stuck for like 3 years now (i fixed it before i was given the car, my mom complained about it and so when i was washing the cars i fixed it for her), and since then it hasnt had an issue, and i'm in and outta the trunk alot, i hate having stuff in the cabin
Damn thing would trip an SOS call every time I started the car.
Not always easy to convince the wife (who is no longer...) to just use the key instead. Oh well.
I actually pulled the latch module out of the trunk lid, sprayed it up with some penetrating oil, worked the mechanism a few times, then re-assembled.
Unfortunately, it didn't stop sticking until the day I came home from cleaning
out the house of a brother-in-law who passed away several weeks later.
At least it saved me from purchasing a new latch module - 7 months or so and it has not stuck once again...
Mine does the same thing with the SOS light coming on. I thought about trying the WD-40 trick and seeing if that works....
I do recall this happening on the last mechanism on my other trunk lid that I ended up replacing since it was damaged.
