Another door pull replacement
Mercedes Benz of Ft. Lauderdale
2411 South Federal Highway
Fort Lauderdale, Florida 33316
203 810 16 51 1434
203 810 15 51 1434
the last four digits are for the trim color. In my case JAVA.
Thirty minutes in the driveway and new pulls installed.
Can you guys believe that my dealer quoted me $250 to repair haha..talk about stealership :/
http://www.youtube.com/watch?v=2Jz696uWxPk
And a write-up here:
http://installuniversity.com/mb/w203...placement.html
I've still got to do mine, but it's too damn cold.
i also have another question if you guys don't mind...i am looking at buying them right now and i noticed that the 03-07 part is a lot cheaper than the 01-02 part. aren't the interiors the same? should i buy the 03-07 part?
203 810 16 51 1434
203 810 15 51 1434
I think it's because it's something unthinkable from any other manufacturer, or atleast it's a problem I've never had to deal with from any other manufacturer.
grab handle breaking... on a Mercedes Benz... wtf...
anyway, thanks for posting the links. wish I knew couple years earlier... would have saved me $200 I paid the stealership! doh!
$40 replacement cost next time, I can deal with that... I'm sure it will break on me again at some point.
why are the dang grab handle so flimsy! argh!
If someone can help you hold the panel you don't have to unhook the door latch or any of the electrical connections. Make sure your torx screwdriver or wrench are magnetic, or use a piece of tape to hold the torx screw on the end of the screwdriver, especially for the screw behind the SRS cap.
