H&r
Old Apr 7, 2003 | 02:34 AM
Benzino's Avatar
03 c230
H&r
The H&R spring will it still mess up the struts even if you dont take a spring pads out? how many fingers can you fit with 19's thru your wheel well?
Old Apr 7, 2003 | 09:29 AM
KompMan420's Avatar
C230K
H&R springs, factory struts and pads, 18" wheels... No problems
Old Apr 7, 2003 | 11:17 AM
KWiK's Avatar
2002 C230 : 2007 C230
ya' need some spacers for those rear wheels
Old Apr 7, 2003 | 11:20 AM
KompMan420's Avatar
C230K
On the "to-do" list
Old Apr 7, 2003 | 12:16 PM
totita's Avatar
C230 K
On the "to-do" list
What size of read pads did you use and which H&R springs did you get? How is the ride after the upgrade, harsher? I can't decide if I should get the eibachs or the H&Rs. I have 17" wheels and don't want to break my neck every thime I hit a bump on the "perfect" Jersey roads. Good looking car by the way.
Old Apr 7, 2003 | 04:08 PM
KompMan420's Avatar
C230K
I didn't change anything other than the springs. I got the H&R sport springs and I think that's all they offer or at least at the time that was it. In my opinion, I think with 17" wheels and the factory struts, you won't notice too much of a difference. I like the way my car rides as a daily driver. If I was going to do any auto-x I'd replace the struts too. In my car if you hit a pot hole or abrupt bump, you feel it for sure, but all in all it's not bad. You should have no problems as long as you drive cautiously and avoid any major obsticles.
Old Apr 7, 2003 | 04:25 PM
c230 sport's Avatar
2003 C230 Kompressor Sport Sedan/2008 M3 Coupe M-DCT/1996 328i (Gone)/1988 190E 2.3 (Gone)
I had both H&R (lowest/stiffest) and Eibach (lower/stiffer) on 2 of my previous cars (both have Bilstein Sport), the eibach is a little bit softer comparing to H&R. So depends on your preference, you'll feel every bumps with either springs anyway, just go real sloooooow when you approach a speedbump.
