C230 HID installation problem, errors and power steering failure
2006 C230 Sport Sedan
![Unhappy](https://mbworld.org/forums/images/icons/icon9.gif)
I tried my best to scour these forums and the ones at BenzWorld for a solution and it looks like I have a completely unique problem. A huge thanks in advance for taking some time to answer. My car is the 2006 C230 Sport - the one with kompressor body style, but the updated 201hp V6.
I have an aftermarket H7 HID kit with a 35W ballast. I installed and mounted everything properly, drilling the holes in the light dust covers too. The lights turn on and work fine on battery power before starting the engine.
When I start the engine I have the following problems and warning notices come up:
-display malfunction
-esp (traction) unavailable
-abs failure
-check engine and abs lights on
-steering tightens significantly (meaning power steering is off and I have to use a fair amount of force to turn the wheel)
From what I have seen in posts here and BenzWorld, people have lights flickering, or bulb failure warnings, or issues with the power to kit. I haven't seen anyone write about the problems I'm getting. Because of this, I have no clue how to approach a solution.
There's some info on the CANBUS, error decorder, capacitors, out there, but none of it is any good. Before I blindly buy more parts to get this working, it would be great to know what you guys think. Thank you.
-abs failure
Drove today during daylight with no low beams connected at all and everything is working.
In the kit, running parallel with the bulb at the end are two cables -blue and black- that have small spade-like connectors. These fit into the stock wired plug which normally goes onto the two ends of the H7 halogen bulb.
2003 c240
sounds like you disconnected your battery and need to do a reset
edit: nm it prob wouldnt cause the power steering failure but the reset might be worth a shot
I saw your email..
I hate to say this as it's probably not the answer you are looking for but if it works without the kit but not with I would abandon the kit. I ran HIDs in my C230 from January 2009 till April of this year before going back to halogens. Bulbs kept failing and at the end, melting. It wasn't worth the hassle even though I loved the output.
I bought my kit from DDM for $89 - a 55W kit. I FULLY expected to throw it away immediately because of issues. But, like it usually is, my C230 proved the exception of the bunch with no issues at all (no flickering/errors of any kind).
A HID kit is not worth the potential damage if your car is balking at it.
I have same exact problem
-abs failure
-abs failure
