AZN Optics 194 LED City Lights
Old Apr 24, 2011 | 03:08 PM
  #301
CHiKompressor's Avatar
2005 c230 S.S.
pm sent
Old Apr 24, 2011 | 11:54 PM
  #302
AZN Optics's Avatar
SPONSOR/MBworld Guru
Originally Posted by havoc_vulture
Asking a question for my cousin...
Do you have LED parking lights for a 2004 VW R32?
he likes my city lights because they have the 8 LED's and wanted to know if you have them for his car ... please and thank you
That'd be a Mk4 right? I've fitted my lights on Mk5 before and worked great, but never tried a Mk4. I believe the parking lights are 3357 though.
Originally Posted by hcalvarez
Mike..not sure if you had any for the fogs already?
I'll be carrying a small run of 9006 HIDs which are your fogs, but majority of my HID line will be H7 and H11 to cater to the larger MB community needs
Old Apr 25, 2011 | 12:49 AM
  #303
havoc_vulture's Avatar
'05 c230 Kompressor SS Mistress
Yes Mike its the MK4
And I believe that is the correct bulb size.
Old Apr 25, 2011 | 10:28 AM
  #304
AZN Optics's Avatar
Well, I currently don't carry that bulb size, but could get it made. However, have not tested on a Mk4 so not sure what the voltage draw is. Normally I would have said it shouldn't be any different than a Mk5, but I can attest to a difference I've discovered between Mk5 and Mk6, so don't want to make any assumptions.
Old Apr 26, 2011 | 12:44 PM
  #305
JJSBENZ's Avatar
C230 Sport
Can someone confirm which bulb for the maps?
License (6411) 36mm
Dome (6411) 41mm
Trunk (6411) 39mm
Map (6411) ???
Mike I sent you my payment for my initial order through google check out.
Old Apr 26, 2011 | 02:08 PM
  #306
giannidy's Avatar
2001 C320
License (6411) 36mm
Dome (6411) 41mm
Trunk (6411) 39mm
Map (6411) ???
I'm pretty sure map lights are 194 wedge bulbs.
Old Apr 26, 2011 | 08:25 PM
  #307
rocafel1a's Avatar
05.C230K.SS
btw how do you pop out the cover of the map lights? i feel like im gona break em
Old Apr 28, 2011 | 01:31 AM
  #308
ML55CLA45's Avatar
2001 c320 - 2002 ml55 - 2011 c300 - 2014 slk350 - 2015 cla45
Which bulbs are you guys finding match factory bi-xenons the best?
Old Apr 28, 2011 | 10:17 AM
  #309
AZN Optics's Avatar
5000K should match best to factory bi-xenons (4300K)
Old Apr 28, 2011 | 09:58 PM
  #310
AnswerSS's Avatar
2004 C230 Kompressor Sedan 6MT
License (6411) 36mm
Dome (6411) 41mm
Trunk (6411) 39mm
Map (6411) ???
Are the License and Dome bulb sizes correct? Was wondering this myself.
Old Apr 28, 2011 | 11:39 PM
  #311
AZN Optics's Avatar
I know for sure the rear plates are 36mm. I haven't personally test fitted the rest.
Old Apr 29, 2011 | 03:36 AM
  #312
snacks's Avatar
2006 c230
payment sent
looking forward to installing these
Old Apr 29, 2011 | 08:00 PM
  #313
JJSBENZ's Avatar
C230 Sport
Got got my bulbs in the mail, did you have any luck removing the cover? Any tips?
Old Apr 29, 2011 | 08:01 PM
  #314
JJSBENZ's Avatar
C230 Sport
I am going to install them this weekend hopefully so I will let you know.
Old Apr 29, 2011 | 08:09 PM
  #315
JJSBENZ's Avatar
C230 Sport
I found this reply on a 07 thread, worth trying...
"For the dome lights on the front, there's a small opening facing the windshield. You can use a flat head to pry that open, but don't force it. If you pull it gently enough, it'll open up. That opens up the light cover, and it'll reveal the dome light. From there, you'll see two white notches (I think they're white). Pull those two notches toward the windshield, and while you're doing that, it'll pull down the entire light thingie-ma-bob (I don't know what you wanna call it) and it'll reveal two little knobs on each side. Those little knobs are what the map lights are kept in. twist it and pull it out and you're taking out the wedge bulb. I'll post pics later if you have any trouble with anything."
Old Apr 30, 2011 | 02:40 PM
  #316
JJSBENZ's Avatar
C230 Sport
Mike,
Update the 6411 36mm LED fits perfect as a replacement for the license plate. However, the dome and trunk 6411 bulb is slightly bigger then the 6411 41mm you currently sell. I measured the stock bulbs and they are about 1 11/16 in. or 43mm for the two dome and one trunk bulb. I put one 41mm and one 39mm as dome replacement and just pushed the tabs in with my finger to make the distance which did not seem to be an issue. I put the other 41mm in the truck and had a hard time getting it secured. I pushed the tabs in but it is held in different from the dome bulb and not sure if vibration/bumps are going to make it come loose. Do you have anything bigger then 41mm?
In addition, I replaced the glove box 6411 bulb with a 39mm and that fit good.
Last, the map and door lights are W5W for those interested
Thanks for the fast shipping.
Old Apr 30, 2011 | 07:07 PM
  #317
AZN Optics's Avatar
I can make 43mm in my next production run, but due to limited models they would fit in, it'd be a smaller run.
Mike,
Old May 1, 2011 | 09:11 AM
  #318
hcalvarez's Avatar
2005 C230 Kompressor
I'll be carrying a small run of 9006 HIDs which are your fogs, but majority of my HID line will be H7 and H11 to cater to the larger MB community needs [/QUOTE]
Mike if you do get a small run of these. Can you let me know? Thanks bro.
Old May 1, 2011 | 01:22 PM
  #319
AZN Optics's Avatar
Mike if you do get a small run of these. Can you let me know? Thanks bro.[/quote]
Probably mid May I'm expecting, depending on when we wrap up our testing of our new integrated error cancelling ballasts.
Old May 1, 2011 | 05:31 PM
  #320
JJSBENZ's Avatar
C230 Sport
I'll take a set of the 9006 HID too when they come available Mike!
I placed an order for the W5W LED bulbs.
Old May 3, 2011 | 06:13 AM
  #321
snacks's Avatar
2006 c230
got my leds great product will have to complete the entire car set
Old May 11, 2011 | 10:33 AM
  #322
AZN Optics's Avatar
Available for immediate sale, I have 1 set of H7 35w 8000K HID kit (low beams) and 1 set of 9006 35w 8000K HID kit (fogs). Both feature my new integrated error cancelling canbus ballasts. $100 per set individually or $175 for both. + $10 shipping via USPS Priority Mail. Let me know
Old May 13, 2011 | 02:30 PM
  #323
eesjunin's Avatar
Nowhere ...Fast
Perhaps this been discussed but any of these bulbs good for the License plate bulb replacement?
Old May 13, 2011 | 02:36 PM
  #324
C230 Mulac's Avatar
1999 E320 4matic Wagon, 2005 C55 AMG - sold, 1998 VW Jetta TDI - sold, 2006 C230 Sport - Totaled :(
Just got my LEDs for the interior yesterday, can't wait to put them in tonight, thanks Mike!
Old May 13, 2011 | 04:39 PM
  #325
AZN Optics's Avatar
36mm festoons for your plate lights. Those are $20/set
