Belt Tensioner M112 (Request for PCY)
For belt tensioned you will need to remove fan and alternator.
Thanks Karo for the WIS instructions for alternator removal and for the chain tensioner removal.
About the oil level sensor, please look at the picture below. The red arrow points to the o-ring I need to replace. In order to replace that o-ring, I would need to drop the lower oil pan, front sway bar in the way and the other cross members are slightly in the way as well. I wanted to know if there is anything else need to be removed before dropping the oil pan.
