P0410 Fix Thread - With Guide [some questions remain though]
2007 ML350
Hi all.
110k 2002 C230 Sport Coupe. Started getting P0410. Cleared it, came back within a day or two.
So I started the search. Found the answers at another forum, and 'volunteer' put together a guide. However, I have some questions (I am hosting the guide temporarily so you guys may look/rehost)
http://www.bencaputo.info/Misc/P0410.pdf
I'm not seeing that many vacuum lines, I must be blind...
I see that
002-140-55-60 is the shut off valve ($72)
I see that 002-140-68-60 is the check valve ($77).
I don't have a good picture/parts diagram of where the check valve is.
In the great PDF made by volunteer, I only see the shut off valve, not the check valve, pictured. However, he is holding a new check valve in the next picture, and had it installed by a mechanic.
Anyone? =)
I hope this helps people out. =)
I see that
Anyone? =)
