M111 Supercharger Transplant
1994 E220 Coupe
Hi guys,
I have a M111.960 (2.2L NA) engine and was wondering if a supercharger from a Kompressor C class would directly fit onto it without problems?
The car is a 1994 124 Coupe (E220C)
ive beeen wondering the same thing.. i want to put a supercharger in my 2006 c280 4matic m272 but im not sure if any of them would fit, and i dont want to dish out 10 grand for a kleemann just yet....
1994 E220 Coupe
Your engine is different though.
My question was more revolving around the idea of if a supercharger kit from a C230K would just bolt onto my engine seeing as they are both M111 engines.
In your case it most definitely would not, not to mention the supercharger may be too small for a 2.8L
In theory, you could bolt on the supercharger, if you get the required pistons, supercharger pulley and belt, etc. You would be better off buying a used engine m111.944 or similar.
C230 komp Manual (rhd)
There is a lot of differences between the early 2.2 m111 engine and the 2.3 komp.
Both use different management.
The 2.2 is das 2 and the 2.3 is das 3.
The supercharger on a 97-2000 M111 has a clutched pulley which works inline with the Cam advancement all through the CAN network.
An early management sytem DAS 2 does not have an extensive can network.
To get the 2.2 to work as Merc intended it to on a 2.3 would be very hard work.
You could bolt on the charger to the early system although you would have to work out a method to close loop the boost and dump off the excess.
TBH you would be better off running an aftermarket turbo system.
A friend of mine has a '96 C220 and unrestricted it has 170bhp.
The C230k >97 will only have 199 bhp unrestricted although the low down acceleration is better, the hassle of getting the supercharger to work on a 2.2 M111 for an extra 30bhp isnt really worth it. Hence why a Turbo system which is tuneable would be much more beneficial for monies!
2006, 200k, 960, aftermarket, c280, e220, engine, fit, kit, m111, mercedes, performance, supercharger, top, transplant, turbo
