HELP - ACC Line in the Trunk SAM - C320
2002 MBZ C320
Hi everyone,
I searched the entire forum and I couldn't find if there is a ACC terminal on rear SAM. I need the ACC line to power small camera in the trunk, and I do not want to disassemble the front and tap into cig. lighter if I do not have to. I found on one of the threads that there might be an ACC line on the SAM, but I can't find the diagram or a picture of a rear SAM anywhere. HELP
1 Post
C320 2002
( Fuse 7 )
Its empty but place a 10amp fuse inside it. With the wire inside..
I use it to power on my subwoofer amp
Power turns on when key is place into and turned on to the second position
2002 MBZ C320
Thanks for the info to both of you. I will check Fuse 7, and since I have voice control and bluetooth I don't think I can use 16. Do you by any chance know what fuse 7 is for. The fuse chart doesn't even list it
1 Post
C320 2002
Fuse 7 will work perfectly fine.. Im currently using it now.. There is no fuse nor anything on the list for it because its a free 12volt power =D
I would not use fuse 16.. Even if you don't have those items your still running power on those cables.
2002 MBZ C320
Thanks Xhale707. I just have a follow up question. What did you use for ground? Also just to make sure the fuse 7 is ACC line (meaning the power is on only when the key is turned)
Thanks again
Thanks again
