MB brake fluid
I'm trying to decide if I want to change it with ATE SL6 or BRF, the only thing holding me back are the viscosity numbers which are 700mm^2/s and 1400 respectively.
If I pick viscosity thats too high the ESP system wont work right (with a 4matic its more critical then in other cars). If too low it might comprise seals.
Also if the MB oem fluid is better then either, I will just buy that.
I found this
http://www.pentosin.net/pressrelease...uperDOT4_3.pdf
Its listed as being a replacement for MB# 000 989 08 07 10 which is our brake fluid. But the pentosin has super dot 4 at 1400 mm^2/s. If I was going with that viscosity I could use and off the shelf fluid. The pentosin low viscosity fluid (@-40*C) is at 700mm^2/s and is not MB approved. So Maybe MB calling their fluid low viscosity is just a marketing scheme? If I could get the numbers I would know.
also bump
https://mbworld.org/forums/c-class-w...uid-flush.html
Being a new owner who wants to do some of his own maintenance is pretty complicated and confusing!
I'll prob just go with the MB fluid, its really high value considering the price and performance aspects. (also the piece of mind that comes along with OEM materials doesn't hurt)
