how to open the driver side dash panel
Old Oct 27, 2010 | 10:02 PM
Basa's Avatar
C240
I need to remove Only the driver's side dash panel. (do not need accessing behind the radio, or center console between the two front seats)!
I have removed the black plastic cover of the footwell area. Also undone screws and connectors from dash panel starting from the left side all the way to the ignition cover/ring. From there on, the dash panel is still tight.
So 1st question is how should I remove the ignition cover/ring. I wedged a few screw-driver bits under it and tried prying it w/ the edge of a med size flat screw driver (trying to not damage the leather), but the cover ring just won't come out. If I pull/wedge any harder it might break!
Also Do I have to open any other areas in order to loosen the rest of dash panel (and eventually remove it)? If so, what items I need to open, and how should I do it.
Any help for this?
Thank You.
Old Oct 28, 2010 | 09:52 AM
pcy's Avatar
pcy
'14 ML350, '13 C220 CDI, '07 C280, '98 ML320
the ring around key comes out by turning counter-clock-wise.
Old Oct 28, 2010 | 10:12 AM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
search. there's an entire thread on this with pictures associated with fixing broken a/c step motors.
Old Oct 28, 2010 | 09:00 PM
Basa's Avatar
C240
not really.
Frank,
That article which is a very good write up for its intended purpose, goes beyond what I need to do. It is not very clear cut for my use - steps 12 & 13 sound like applicable in my case, but don't seem to be enough. Now using any other part of it overlaps w/ opening the center and right side of dash - something not in my agenda.
My aim is only to open/remove driver-side dash.
Thanks.
Old Oct 28, 2010 | 11:16 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
it tells you how to remove the entire dashboard including the driver side in that thread.
Old Oct 28, 2010 | 11:29 PM
Basa's Avatar
C240
overlap overlap
thanks Frank.
I am gonna wait to see if I can find a way of doing this w/o touching the center console, ashtray, radio, etc.!
If I see no other way only then I would touch those parts (according to that write up you have to dismantle all those other pieces too).
Old Oct 28, 2010 | 11:42 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
that's because you do. it's one single piece from your knee to the side of the center console.
Old Nov 2, 2010 | 11:33 PM
Basa's Avatar
C240
Hey Frank,
You really ARE out of control - look at the number of postings you have.
You must take your computer to work while it is logged on mbworld.org - all the time
BTW, Yeah, there was no other way - I had to open all the parts. What a pain.
