CrankShaft pully?
Old Nov 16, 2010 | 11:19 PM
Xhale707's Avatar
C320 2002
CrankShaft pully?
Its like one thing to another now on my car like wtf.. I was reading around was there a recall on this pully?
Seems like the pully is cracking or something. I think its been like this for a while but i just really looked at it today.
Old Nov 17, 2010 | 07:40 AM
pcy's Avatar
pcy
'14 ML350, '13 C220 CDI, '07 C280, '98 ML320
you don't want to wait until that "harmonic balancer" goes out. When that balancer goes out, it will damage lot of other components in the engine compartment.
There was a recall on M112 engine's harmonic balancer on W163 and it is a well-known problem on W163. If I am not mistaken your W203 (M112) shares has the same engine as ML.
I am NOT sure whether there are any recalls on harmonic balancer on W203 (M112).
Old Nov 17, 2010 | 11:10 AM
Xhale707's Avatar
C320 2002
Ill go to the dealer and ask them about it.. There better be lol. I was checking it out and the parts only 90 bucks so its not that bad.
Old Nov 17, 2010 | 11:31 AM
fookoo303's Avatar
2003 c240
damn... i better go check mine. i got 170k miles on mine and never looked at that.
Old Nov 17, 2010 | 11:48 AM
pcy's Avatar
pcy
that pulley is essentially two metal pullies with a rubber pulley sandwiched in the middle.
Replacement of that harmonic balancer is relatively easy by taking out the belt and then the big bolt in the middle of the balancer. Part is also not that bad (less than $100).
Make sure you torque that bolt to the correct spec.
Old Nov 17, 2010 | 07:26 PM
JLD2k3's Avatar
2002 C320
Is there any benefit to the lighter pulleys that are available aftermarket?
Old Nov 17, 2010 | 07:35 PM
FrankW's Avatar
MBworld Guru
W206 PHEV AMG
depends on how much "light weight" is.
Old Nov 17, 2010 | 11:35 PM
splinter's Avatar
Super Moderator
GMC - Miata - Trek - P-Car
MB ostensibly improved its later M112 and M113 torsional dampers.
No W203 was subject to the 360,000+ vehicle Service Campaign (recall), although some were replaced under the auspices of goodwill.
Xhale707’s does look a bit tired. Pitched mine a while ago for evosport’s ODPS. For safety’s sake.
Old Nov 18, 2010 | 07:43 AM
pcy's Avatar
pcy
Thanks splinter for posting that recall letter.
I wonder why 203 model is not listed while M112 is in some of the 203 model as well.
From my experience with ML (W163), I check on the harmonic balancer every time I open the hood.
Old Nov 18, 2010 | 09:35 AM
Xhale707's Avatar
C320 2002
Wow wow i may head to my dealer with that letter and see if i can get some lee way. I remember someone saying they took there car in and they only had to pay for labor which is still the same price as the part lol. But you never know.. If it was an issue i don't see for them NOT to fix it
Old Nov 18, 2010 | 02:50 PM
samaritrey's Avatar
Super Moderator
THE C350
Great mine looks worse the yours i would say time to add this to my list of things to replace.
Old Jan 3, 2013 | 05:56 PM
panzafio's Avatar
2002 c240
Harmonic Balancer replacement
Is there a D.I.Y for the Harmonic balancer. I saw a couple of youtube videos, and one guy used the breaker bar w/ 27mm shallow socket and a homemade tool to keep the balancer from spinning. I also saw another video where the mechanic just locked a breaker bar into position, disconnected the distributer cap and turned the ignition key to break the nut on the balancer loose. this is not optimal method but how do you get tight again?? thanks!
Old Jan 4, 2013 | 01:18 PM
SickSpeedMonte's Avatar
2007 C230 and 1985 Monte SS
I would recommend leaving your distributor cap alone. That seems like a really good way to break your hand too.
Is there a way to hold the flywheel with a screwdriver by removing a splash shield on these cars? Either that or a piston stop in the spark plug hole is how I do it on small block Chevys.
Old Jan 4, 2013 | 02:28 PM
Carsy's Avatar
2007 W204 220CDI Classic Sedan
I would look at locking it with the ring gear even if I have to take out the starter motor.
Old Jan 4, 2013 | 02:53 PM
panzafio's Avatar
2002 c240
Is there a rubber cap on the bottome of the bell housing of the tranny? I will look into both suggestions. Thanks!
Old Aug 29, 2013 | 10:30 AM
Chris.cardo's Avatar
2008 CLK350
Can anyone tell me where to find the Torque specs on a harmonic balancer for an 08 CLK 350?
