2002 C230k vs. 2003 C320
1991 mr2 turbo, 2002 coupe
Well actually its 192hp/200ft-lbs VS. 215/221 and I believe they're within a hundred lbs of each other so I'm sure you can draw your own conclusions. The 2002 6sp coupe runs the 1/4 in ~15.7 per R&T and the C320 sedan (auto) runs it in 15.1. I'd guess the 6sp C320 coupe would be a high 14s car although I don't believe its actually been tested yet.
2002 C230 K
![Roll Eyes (Sarcastic)](https://mbworld.org/forums/images/smilies/rolleyes.gif)
The V6 is 55 lbs heavier than the M111.
The C320 will be considerably quicker. Now add a pulley to the M111 motor and you've got yourself a race.
Cheers, BT
[QUOTE]Originally posted by trench
[B]It should be 192hp/206ft-lb. for the M111. Every metric figure I've ever seen for this motor is 280 Nm of torque, which is 206.5ft-lb. Yet another mistake perpetuated by MBUSA
Right, I think the manual actually quotes 208 if I'm not mistaken, but I figured 200 was the generally accepted number here although probably wrong like you said. I wonder what would motivate them to understate this? Good point though.
2002 C230 K
"Maximum torque acc. to SAE J 1349 207 ft.lb/2500–4800 rpm"
Cheers, BT
