Pogijeffrey's W203......
05 c230 kompressor
05 c230 kompressor
2003 c240
Get it on a lift and see if there is cracking on the rubber. For me, all four were cracked. I'm not sure the cost to pay someone else to do it. I bought the bushings for about 20 each and replaced them myself. I had carquest press them in for 20 dollars. But buying the entire control arm is relativeley cheap also. I think you can ge tall four for under 300 on rmeuropean.com. Just be sure to buy the OEM ones. I've heard of the aftermarket balljoints failing prematur.ely
05 c230 kompressor
#36
1 Post
C320 2002
Car looks good. I liked it with your first set of brabus reps though. Make sure you change your rear diff Fluid to go along with your services. I would also grease up the wheel bearings if they haven't been changed or serviced.
#37
05 c230 kompressor
Me too bro., but the company discontinued those
#38
2005 C230 Kompressor
