Power Steering Pump..Request vdemon311
Old Mar 17, 2011 | 03:24 AM
W203E35's Avatar
2006 C350 Sport 6MT
I'm surprised you power steering pump went out. Are you sure you didn't do any doughnuts?
Old Mar 17, 2011 | 03:53 PM
vdemon311's Avatar
2006 c230
yeah idk...it didnt go out just sounds like it is about to go out... Terrible whining noise
Old Mar 17, 2011 | 04:01 PM
vdemon311's Avatar
2006 c230
I'm all about preventative maintenance, especially on my DD... something starts making noise... im going to replace it
Old Mar 17, 2011 | 04:19 PM
billbillw's Avatar
2001 E55 AMG (sold)
Did you try replacing the fluid first?
Old Mar 17, 2011 | 05:07 PM
vdemon311's Avatar
2006 c230
of course.... weeks ago i fully flushed it with 1 quart and replaced it. It was easy to diagnose that P/s pump was making the noise. Remove the serpentine belt from the car. Run the car and you will find out whether or not it was the pump-pulley from the P/s pump
Old Mar 19, 2011 | 01:23 AM
BABYBENZZZ's Avatar
BENZ w203
lol
i seen pumps online for 100$ relax, it takes 5mins
Old Mar 19, 2011 | 02:11 AM
Silver C's Avatar
C240
Hi guys, i just switched from a bmw e46 to a c240.. Is the steeringnwheel stiffer on benz normal as compared to a bmw?
Old Mar 20, 2011 | 12:48 PM
vdemon311's Avatar
2006 c230
Hhmmm..where are these 100$ pumps you speak of? If you could point me in the right direction cause all I see is 400$ pumps
Old Mar 20, 2011 | 05:19 PM
samaritrey's Avatar
Super Moderator
THE C350
+1
Old Mar 21, 2011 | 02:37 AM
BABYBENZZZ's Avatar
BENZ w203
power steering pump
http://cgi.ebay.com/ebaymotors/NEW-P...Q5fAccessories
ya pretty easy fix, do the belt too
Old Mar 21, 2011 | 04:46 AM
W203E35's Avatar
2006 C350 Sport 6MT
Very impressive, the cheapest brand new I saw was $380
Old Mar 21, 2011 | 04:49 AM
BABYBENZZZ's Avatar
BENZ w203
just dont bend over and take it to BENZ
Old Mar 21, 2011 | 07:45 AM
vdemon311's Avatar
2006 c230
Great find thanks, my car isn't listed under the vehicle fitment with that pump though.^^ Just changed my serpentine belt when I changed my belt tensioner and guide pulleys last month. I keep thinking... would I have to replace the gasket for the reservoir when I switch it from the original pump to the new one, or can I just reuse mine? If this part fits , I am ready to order and do this the upcoming weekend, but I am pretty sure that the part above does not fit (looks like 400$ pump it is). More garage time woohoo
Old Mar 22, 2011 | 01:42 PM
pcy's Avatar
pcy
'14 ML350, '13 C220 CDI, '07 C280, '98 ML320
... would I have to replace the gasket for the reservoir when I switch it from the original pump to the new one, or can I just reuse mine? ...
I'd recommend you get a new o-ring (aka gasket) and a new lock pin. New o-ring is only few bucks. If you re-use the old o-ring and it starts leaking after replacing the pump, then you will have to empty the reservoir and replace the o-ring. Go ahead the replace the o-ring.
Old Mar 23, 2011 | 12:46 AM
splinter's Avatar
Super Moderator
GMC - Miata - Trek - P-Car
…and top off (or preferably flush the entire circuit) with Pentosin CHF 11S fluid while you’re in there:
reference
Old Mar 26, 2011 | 10:58 AM
vdemon311's Avatar
2006 c230
thanks for all of the above.... will post updates once the pump is in and running.
