Help me guys
Old Apr 10, 2011 | 06:21 PM
Cheb44's Avatar
2007 C230
Help me guys
Okay here is my deal, got home Friday night and all was good, went to start the car Saturday and the car is just turning over. No Codes no previous problems other than I replaced the magnets on the cam position sensor about 2 months ago. Only thing I have done recently is change the oil last week.
What I am thinking is its the CPS and just isn't popping a code because it hasn't ran since going bad? Other than that, maybe the fuel pump but I didn't have any problems starting or any of the normal fuel pump warnings.
If it is the CPS or something else where is the best place to purchase the part? Thanks ahead of time guys.
BTW 2007 C230 with a 7 speed.
Old Apr 10, 2011 | 07:58 PM
ncmudbug's Avatar
2005 C230K, 2019 Honda CR-V, '74 Lotus Europa
I'm new to Benzes but I would try to narrow it down. I would start to try to determine if you're getting spark and fuel.
You can at least determine if you're getting fuel pressure by relieving the fuel pressure (there should be a schrader valve that is used to relieve fuel pressure before changing the fuel filter). You could try that after you've tried cranking it. If you have no fuel pressure, that could be your problem.
To check for spark, you can get a checker at most auto parts stores. It's pen shaped and you touch it to a spark plug wire. It lights up if you have spark. Now what I don't know is if this will work on MBs because the coil basically sits on top of the plug so I don't know if there will be enough voltage before the coil to light the light in the pen.
Old Apr 10, 2011 | 09:01 PM
OneOfaKindTrini's Avatar
Nike Turbo Shox
Does the car have any life when you put the key into the ignition?
Old Apr 10, 2011 | 09:03 PM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
He said the car is turning over, which means it is cranking like normal.
Old Apr 10, 2011 | 09:15 PM
Nike Turbo Shox
Mash the gas when you turn the key.
Old Apr 10, 2011 | 09:57 PM
Cheb44's Avatar
2007 C230
yeah voltage wise everything is good and its turning over like a champ it just isn't starting.
I have heard the Crankshaft position sensor causes the engine not to start, but does it turn over like normal when the sensor is dead?
Old Apr 10, 2011 | 10:02 PM
Silver C's Avatar
C240
Fortunately I haven't had the sensor problem you mentioned, but as far as I know it shouldn't have turned over and dies.. But there's no harm in checking, but shouldn't the dead sensor throw a malfunction warning?
Old Apr 11, 2011 | 12:36 AM
phister's Avatar
06 C230 SS 6spd
take them apart and make sure its in properly. from there check your voltage from your battery to see if its giving the right amount. Have you tried jump starting the car to see if it cranks over?
Old Apr 11, 2011 | 05:26 AM
Silver C's Avatar
C240
Phi, if he can crank his car shouldn't the battery be good?
Old Apr 11, 2011 | 06:12 AM
phister's Avatar
06 C230 SS 6spd
if you battery has just enough juice can still try and crank. You check if its your battery by turning on the headlights then trying to crank the car, if the light starts to dim its the battery. But its sounds like something else. I'd check the CPS first since its what you tinkered with last.
Old Apr 11, 2011 | 07:01 AM
LILBENZ230's Avatar
CPS or fuel pump. Check fuel pressure if possible to eliminate that possibility.
Old Apr 11, 2011 | 07:02 AM
LILBENZ230's Avatar
https://mbworld.org/forums/c-class-w...lp-needed.html
Old Apr 19, 2011 | 11:01 AM
johnand's Avatar
Super Moderator
2007 C230SS; 2014 ML350 BT
Looks like another 07 with premature fuel pump failure
Old Apr 19, 2011 | 01:26 PM
carbonfiberwhor's Avatar
2006 C230, 2006 BMW M3, bye bye C55:(
I didnt realize this was a problem with the 07's. Good to know
Old Apr 20, 2011 | 11:07 AM
Cheb44's Avatar
2007 C230
in the process of removing the fuel pump the connection on the bottom of the top cap of the fuel pump had a burnt spot on it.
That's really nice to know something in my fuel tank got hot enough to burn a connector whether the pump shorted or the connection shorted its not cool.
Old Apr 20, 2011 | 11:23 AM
fookoo303's Avatar
2003 c240
wow thats the second time ive heard of this happening in the past couple months. Sounds like this might become a common problem. How many miles do you have?
