Interesting V6 guide
Old Apr 17, 2011 | 09:19 PM
phister's Avatar
06 C230 SS 6spd
Found this info on another forum and thought I'd share.
M112 E26
The E26 is a 2.6 L (2597 cc) version. Bore is 89.9 mm and stroke is 68.2 mm. Output is 170 hp ECE (125 kW) at 5500 rpm with 240 Nm (177 ft.lbf) of torque at 4500 rpm.
Applications:
1998–2005 C240
1998–2004 CLK240
1998–2004 E240
M112 E32
The E32 is a 3.2 L (3199 cc) version. Bore remains at 89.9 mm but the engine is stroked to 84 mm. Output is 218 hp ECE (160 kW) to 224 hp ECE (165 kW) at 5700 rpm with 315 Nm (232 ft.lbf) of torque at 3000-4800 rpm. It has fracture-split forged steel connecting rods.
Applications:
1998–2004 C320
1998–2004 E320
1998–2005 S320
1998–2003 ML320
1998–2004 CLK320
1998–2003 SLK320
2003–2008 Chrysler Crossfire
M112 E32 AMG
The E32 AMG is a special version of the 3.2 L (3199 cc) E32, fitted with a helical twin-screw supercharger and water-to-air intercooler. The supercharger was developed in conjunction with IHI and features Teflon-coated rotors producing overall boost of 14.5 psi (1 bar). Output is 354 hp ECE (260 kW) at 6100 rpm with 332 ft.lbf (450 Nm) of torque at 3000-4600 rpm.
Applications:
2001–2003 C32 AMG
2001–2003 SLK32 AMG
2005–2006 Chrysler Crossfire SRT-6
M112 E37
The E37 is a 3.7 L (3724 cc) version. It retains the 84 mm stroke of the E320 but is bored to 97 mm. Output is 235 hp ECE (173 kW) to 245 ECE (180 kW) at 5750 rpm with 254 ft.lbf (344 Nm) of torque at 3000-4500 rpm.
Applications:
2003–2005 ML350
2003–2006 S350
2003-2006 SL350
M272 E25
The E25 is a 2.5 L (2496 cc) version. Bore dimension is 88 mm and stroke is 68.4 mm. Output is 204 PS (201 hp/150 kW) at 6100 rpm with 181 ft·lbf (245 N·m) of torque at 2900-5500 rpm.
Applications:
2004–present C230
2005–2009 E230
2008–present CLC230
M272 E30
The E30 is a 3.0 L (2996 cc) version. Bore is 88 mm and stroke is up to 82 mm. Output is 231 PS (228 hp/170 kW) at 6000 rpm with 221 ft·lbf (300 N·m) of torque at 2500-5000 rpm.
Applications:
2004–present SLK280
2005–present CLS280
2005–present CLK280
2005–present C280
2005–present E280
2005–present SL280
2006–present R280
2007–present S280
M272 E35
The E35 is a 3.5 L (3498 cc) version. Bore dimension is 92.6 mm and stroke is 86 mm. Output is 272 PS (268 hp/200 kW) at 6000 rpm with 258 ft·lbf (350 N·m) of torque at 3500 rpm. A direct injected variant debuted in 2006 under the name Stratified-Charged Gasoline Injection (CGI). First fitted to the CLS350 CGI, it produces 292 PS (288 hp/215 kW) and 269 ft·lbf (365 N·m) of torque while lowering fuel consumption. In 2008, the non-CGI engine was uprated to 316 PS (232 kW) at 6500 rpm and 265 ft·lbf (360 N·m) of torque at 4900 rpm. This was achieved by raising the rev-limit to 7200 rpm, increasing the compression ratio and other modifications to the valvetrain.
Applications:
2004–present SLK350
2004–present CLS350
2005–present CLK350
2005–present C350
2005–present E350
2005–present S350
2005–present SL350
2006–present R350
2006–present ML350
2005–present Viano
2006–present Sprinter
2008–present CLC350
2008–present GLK350
M276
The Mercedes-Benz M276 engine is a direct injected, V6 gasoline automotive piston engine.
There has been one variant of the M276 engine announced so far.
This version has a displacement of 3.5 liters (3499 cc) with a bore of 92.9 mm and stroke of 86 mm. Output is 306 hp (225 kW) at 6500 rpm with 273 ft·lbf (370 N·m) of torque at 3500-5250 rpm.
Old Apr 17, 2011 | 09:27 PM
giannidy's Avatar
2001 C320
Ooooh good post! M112 E32
Old Apr 17, 2011 | 09:54 PM
Silver C's Avatar
C240
Thanks for sharing Phi! I just realized rye c230 has actually more HP than the c240!
Old Apr 17, 2011 | 10:59 PM
Gynecologist MD's Avatar
Hopefully another MB soon..
Almost every car on that list has more HP than ours, lmao.
I should have a M112 E26, right?
Old Apr 17, 2011 | 11:01 PM
CanadianSteel's Avatar
2006 C230 6 speed
The M272 really comes alive after 3k RPM. I find myself living over the 4K range with my 06 more then i did with most other cars i owned, the chart makes it clear why
Old Apr 18, 2011 | 10:13 AM
mskembo's Avatar
2010 Mercedes-Benz E350
M272 E25
M272 E30
If the bore is the same, then replacing the crank (and possibly arms) would change a E25 into an E30? Does the E30 share the dual runner manifold? I understand that there would need to be some ECU tweaking, but that sounds really interesting.
