Passenger Window Goes up in Steps
Old Apr 20, 2011 | 12:58 AM
csaunder's Avatar
2001 C320
Unhappy Passenger Window Goes up in Steps
My front passenger side window will not roll up properly anymore. If I'm rolling it up from the drivers side controls I have to hold the control up the whole time but the window goes up in 1 inch increments and finally makes it to the top. From the passenger side if I hold the control unit up it stops every inch or so and I have to release the control and then hold it up again and again to get the window up. The window rolls down fine from both controls.
Also, while rolling the window up from either the drivers side or pasenger side controls the lights in the door (control knob and memory button) flash on and off like there is a power issue.
Any suggestions? This is just one of many issues with my C320 that I want to fix before I sell it...soon hopefully.
Old Apr 20, 2011 | 01:11 AM
Star Rider's Avatar
My Ride
If you check the manual it tells you how to re-sync them. As I recall you close the window with your finger but don't let go yet. Continue to HOLD your finger in the "Close" position for 3-5 seconds. This should tell the window to re-sync with the others.
Old Apr 25, 2011 | 01:16 PM
csaunder's Avatar
2001 C320
Star Rider - thanks for your suggestion but no go.
I tried synching the window but no luck. I know I did it right as I had to replace my battery this weekend and was able to sync the other windows/sunroof. Any other suggestions?
Old May 2, 2011 | 05:01 PM
csaunder's Avatar
2001 C320
So no one else has had this issue, just me???
Old May 2, 2011 | 09:42 PM
WaveyKat's Avatar
Something Slow
my driver side rear only has Express down and not up :-( sync doesnt work.
