hissing sound from headlight levelling roller.
Old Apr 30, 2011 | 03:24 AM
Silver C's Avatar
C240
Guys, I have a significant hissing sound that sounds like a vacuum leak from my headlight levelling roller.. If I click it down to position 3 the sound is minimized, but when I move it to position 0 the sound is quite loud! I don't know what tosearch for so I'm sorry if this is covered before..
Thanks..
Old Apr 30, 2011 | 03:28 AM
Silver C's Avatar
C240
Here is the sound coming from..
Old Apr 30, 2011 | 03:30 AM
Silver C's Avatar
C240
Oh btw, the sound comes up whenever I turn the engine on.. Doesn't matter if the light is on or off..
Old Apr 30, 2011 | 03:35 AM
Moviela's Avatar
There is a single screw holding the assembly you can access from below. Then pull it out and check the vacuum hose connected to the control. If it is just the hose, replace it. If the valve is bad you need to hand over some Rupiah for a new switch assembly.
Old Apr 30, 2011 | 03:40 AM
Silver C's Avatar
C240
Thanks moviela, will check as soon as my fever drops.. But just wondering, where does the hose lead to and where is thevacuum pump located at?
Old Apr 30, 2011 | 03:56 AM
Moviela's Avatar
The hose leads to the headlights, and the vacuum is from the engine. That is why you only hear it when the motor is running.
