Low boost ? Common boost leaks ?
Old May 27, 2011 | 11:18 AM
Benztecg's Avatar
c230k
Hey, I installed boost gauge on my 2002 m111 and i only get 5.2 psi of boost max, is there common places for boost leaks , is suspect leak around MAF, is there any more common leak spots ?
Thank you.
Old May 27, 2011 | 12:35 PM
Jp's_C230k_W203's Avatar
2005 c230 kompressor
How long has it been in the car? I would first check where you tapped the lines.
Old May 31, 2011 | 05:54 PM
Benztecg's Avatar
c230k
there is 2 factory premade ports on the intake with 2 rubber plugs so i removed one and ran plastic line to gauge sensor.
Old Feb 9, 2022 | 07:09 AM
dgian's Avatar
C200 W203 2.0l
@Benztecg did you manage to find why you had 0,37bar boost? currently having the same issue. please reply
