Comments on Fabulous kit !!
Old May 25, 2003 | 04:34 AM
JeT's Avatar
JeT
Hi Ab-ab,
You'll really have to wait until Wong_Edan logs on but I think he cut all 4 with stock shocks.
S_kLaSse's Avatar
300E
Not for every day use.
Its a bit too japanese. but look nice though. one of a kind.
Old May 25, 2003 | 04:42 AM
dronellis's Avatar
EUropean Freaks
What???are u kidding me??? japanese style wont be like this dude! hahahhaha
Old May 25, 2003 | 07:27 AM
W0n6_3d4n's Avatar
C200K (w204)
I'll try to lower the car more, I want to slam it for the Brisbane AutoSalon in September, hehehe. That picture was with my cut Eibach, no idea how many coil my friend cut, but only 2.5 coil left for the front springs. Rear spring only 1 coil cut. And yes, i was using my stock shocks, ride was horrible compare to the Coilover one, but still acceptable
Is the lowest C class in Seattle ever got in the Permaisuri?? just wondering, hehehe.
Old May 25, 2003 | 09:11 AM
tomz_racing's Avatar
c320 (w203)
W0n6_3d4n,
What size are the wheels front and rear ? 19 x8.5 all around or you go widder at the rear ?
dronellis,
Felixxx... .. haha.. i am gonna use it every day though.... but i agree with S_kLaSse, they have japanese style on them .. since fabulous is orginally from Japan.. don't you remember haha...
Old May 25, 2003 | 10:04 AM
W0n6_3d4n's Avatar
C200K (w204)
Front is 19 x 8 ET37 (offset too big), Rear is 19 x 9 ET24 (perfect)
Old May 25, 2003 | 01:03 PM
  #32
c320 (w203)
isn't the offset for our car is 35 mm ???
Old May 25, 2003 | 07:59 PM
  #33
W0n6_3d4n's Avatar
C200K (w204)
I looked into my original wheels and it come with 37. Well the wheels just fit perfectly, I can even use the original bolt, without the need of machining them.
Old May 25, 2003 | 10:38 PM
  #34
Ab-ab's Avatar
W203 and W211
Wong Edan,
Are you planning to cut your carlsson coil over spring? :p
Ab-ab
Old May 25, 2003 | 11:33 PM
  #35
W0n6_3d4n's Avatar
C200K (w204)
It's impossible to cut the front one as each coil has different size. For the rear one I'll replace the spring with my eibach one.
Old May 26, 2003 | 12:41 AM
  #36
shortbear's Avatar
the fabulous kit makes the car look cheap. There are some much better body kits out there if you want to modify your car.
Old May 27, 2003 | 04:50 AM
  #37
Ab-ab's Avatar
W203 and W211
Wong Edan,
Im thinking of that too,.. I am using H&R coilover right now,..and i couldnt drop my car (espcially the front one) to the extent i want. I'm thinking of replacing both the front and the rear with the H&R springs + stock shocks and cut the coils. But the ride will be very very bumpy..I guess I had no other choice,...hehe
Ab-ab
Old May 27, 2003 | 10:21 AM
  #38
Guest0001
Guest
Posts: n/a
damn it someone just ruined a perfectly good C class!!!
that fabulous bodykit is the most disgusting thing ive seen!!!
Old May 27, 2003 | 09:43 PM
  #39
BrabusCClass's Avatar
GL450, Sienna SE
LOL.
Old May 27, 2003 | 09:51 PM
  #40
c320 (w203)
W0n6_3d4n,
How many piece is the LD1 wheels ?
Old May 28, 2003 | 02:38 AM
  #41
W0n6_3d4n's Avatar
C200K (w204)
Ab-ab, the front coilover can be dropped up to 2 inches, but to be able to do that u will need a low offset wheels, i need to put 15mm of spacer for my front wheels, so i can lower it at the lowest level :p. Btw, how low can u dropped your rear one?? mine is not that low and i'm thinking there could be sth wrong with the installation.
My LD1 is 3 pieces
Old May 28, 2003 | 06:40 PM
  #42
Ab-ab's Avatar
W203 and W211
Wong Edan,
I use maya tts with offset 31, I also need to use spacer for the front wheels since the front tires are rubbing the spring. I use 5mm spacer, i try not to use more than that because i'm afraid i cant turn my steering wheel more than 1/4 after i lower it. For my rear part, I still have a finger (kelingking :P) to go until my fender touch my wheels lips. I'm not sure whether it is the lowest or not but im trying to check it myself probably later next week. Do you have msn? could you please add me to ure list my email is ab2_js@hotmail.com or if possible drop me an email (ngomong di imel lebih enak), thanks dude
Ab-ab
Old May 28, 2003 | 09:02 PM
  #43
W0n6_3d4n's Avatar
C200K (w204)
I've add you in to my list, my email is reja_e@hotmail.com
Old May 31, 2003 | 08:25 AM
  #44
CarlssonCRS's Avatar
r171
you shoulda got 19x9 front and 19x10 rears if you want a thicker lip!! LD1s are nice.... but not in chrome.... if i wanted to save money i woulda bought LD1s for sure.
